Hey Guys...
The "Poor Sheathmaker" that G19 is speaking about is me.
Most of you know me,, most of you have my sheaths...
Hopefully most of you know that I'm not a Hack when it comes to sheaths...
Before I go into detail and defend myself,, here are a couple of pictures of the sheath, knife and said damage.
Edited to Say:
These pictures were taken 15 minutes before they were packaged and shipped.
As you can see by the first picture, that it is a Quality job, and I know a little about sheathing knives. I've literally made thousands of sheaths for Busse knives and several dozen of these Sand powder coated knives. The sand poder coated knives they ALL have the same effect with rubbing.
The second picture, a closeup of the knife, shows slight rubbing in the center of the blade, and No wear at the tip.
First off anyone that has a Tan Sand powder coat knows that this finish is very delicate and the particles are Easy rubbed off, even by picking at it with a fingernail.Once the particals come off the rubbing for the most part ceases to happen.
This particular powder coat is prone to rubbing, no matter what you do to it.
Having Alot of experience with this Sand powder coating, I took extra precautions to help prevent this, by adding extra layers of tape, however I Cannot be expected to completely eliminate and rubbing with this type of powdercoat. It is the equivilant to having 150 grit sandpaper glued to the sides of the knife..
It is Impossible to prevent, and common sense should tell you that this is going to happen.
As soon as the handle leaves the sheath, if the knife isn't Exactly centered All the way out of the sheath, which is Absolutely Impossible to do, especially with the contour of the knife, the knife touches either side of the sheath, and rubbing occurs. Nothing I can do about it...
This isn't a problem with other knives, because the powder coating is smoother and it simply slides on through.. Especially with the lubrication I use in my sheaths.
It is Only a serious problem with the Sand powdercoat. Which is Basically a nightmare to work with.
Chuck Expressed to me that he was unhappy with the rubbing and Expected a Mint Collector back. Only After he recieved the knives did he inform me that this was a MINT Collector Knife, which I take now as being a Safe Queen.
Had I known that it was A Mint Collector Safe Queen and he expected it back in Mint condition I would have Refused the job Hands Down!
The knife was presented to me as a User knife, as I talked with him at least twice in Detail how he was going to carry it.
In the 14 email conversations, and at least one phone conversation we have had, not once was MINT Collector brought up or Expressed to me.
Mint Collector Knives, especially if you want them to stay in that condition Should Not be Carried, and once they are sheathed in ANYTHING, Especially with this particular powder coating cannot be Expected to stay in this condition.
Now I'm Expected to fix the problem.
I'm Very upset that Chuck is Not happy with the job, these types of things Bother me Greatly and I don't like it one bit.. An unsatisfied customer is a customer that doesn't return, which does me Absolutely no good.
ttyle
Eric E. Noeldechen
On/Scene Tactical
