Positive firsthand experience with Lynn Thompson
Seems to me that Mick HAS been saying that Cold Steels do have one of the best, if not the best, performance/materials/strength to price ratio FOR THE MONEY. And when he said that sub $100 CS folders being able to trump some $1000 knives in real world cutting, that is true.
A thin hollow or full flat grind from CS can cut better than some of the overly thick "Overbuilt" grinds of example, Medfords, or some of the ,while pretty, compound or "Nightmare" grinds of other $1000+ customs and still have a stronger lock than the titanium framelocks.
I think Mick has been saying some relevant stuff.
Sent from the BatComputer
Thanks man, you're probably the only person that's seen my point this entire thread. I'm talking about a knife covering all attributes for a good price, it's hard to find a knife that is both extremely strong, that still cuts really well and uses good materials - at a good price. Some people think i'm being a fan boy just cos CS happens to offer knives that do this.
No problem dude. However, am not trying to be a righteous person or anything, but it's probably best to keep the insults away from general discussions regardless how heated the discussion becomes ☺
What knife is that?
Cold Steel Code 4, a sub $80 knife that offers super strong construction, is lightweight , a thin hollow grind, and CTS XHP steel.
It's a good value for the money.
Whether it's the best value for the money depends entirely upon what you find valuable in a knife.
IMHO the Spyderco Delica and Endura are a better value for the money on the strength of Spyderco's customer service and their consistent production quality, but it's basically a wash and a matter of preference. The Ontario RAT folders are a better value for half the price.
The Code 4's Tri-Ad lock is stronger than the RAT's liner lock and probably stronger than the Spyderco's back lock, but I don't really think that's relevant because none of the locks are likely to fail under any reasonable use for a folding knife of that size.
All three have different handle materials, but I'd give the edge to the Ontario and the Spyderco, but that's because I prefer G10 or micarta handles in the cold temperatures that predominate in my location, and I like the grippiness of Spyderco's Volcano and bi-directional texture enough to overlook the FRN handles. I think if you're going to do metal handles, they should be titanium for the balance of strength and looks vs. aluminum and weight reduction vs. steel.
Blade steel is largely a matter of preference, but CTS-XHP is a minor improvement over D2 and VG-10. So if blade steel is your most important attribute, and you're limited to the $100 range, then the Code 4 is a good choice.
I would, however, rush to add this:
I think for $50 you can get about 70% of the value possible out of a knife, which is more than enough for anyone- a well-manufactured knife made to good quality standards out of good materials. For $100 you can get 80% of the value, typically getting better handles or blade materials (seldom both), but the manufacturing quality isn't really any better.
For $200, you can get 90% of the value, with some small but noticeable increase in manufacturing quality in terms of fit and finish and usually a marked upgrade in handles and blade material- the $100-$200 range is where you start seeing G10 and micarta that are more than simple slabs and where you start seeing titanium and the current generation of 'super steels.'
After that price point, you're paying increasingly more for small increases in fit and finish quality that require closer and closer inspection to find until you hit the $500 price point, at which point you're paying for miniscule increases in fit and finish, artistic value, or the uniqueness of limited-production or custom work.
That's just my opinion.
Cold Steel has a subforum here with a moderator who is supplied by and is a rep for Cold Steel. So CS can get feedback. Its where these customer service things should be addressed.
And if you dont want to deal with all these "haters" and "tough guy clowns" that is the place for you to go. Here in General, you will get opinions on both sides.
You like CS? Great. Many do. Many don't because they have a owner/video maker and products that people find silly and/or makes knife fans look like nutjobs.
They make some decent, reasonably priced stuff that works. I find them great "starter" knives.
I find them great mid range knives. The knives could be considered "starter" based on their price. Or mid range or better based on build quality, strength, ergonomics,and blade steel. Those two characteristics add up to high value. As a long time Spyderco fan and Benchmade customer, I ve developed a high regard for certain Cold Steel folders. Not as many knives out there that are high quality for a reasonable price as there used to be. Map pricing discourages some discerning enthusiasts. :(
bang for buck for a hard working knife that will last with good materials (currently) CS are hard to beat.
I think that s true. The recipe for a successful knife company. Work on customer service will only polish the brand. My personal experience with customer service on the phone has been fine.
You just don't get it, it's easy to cherry pick attributes. Yeah there are plenty of knives that excel at "cutting" look at a cheap opinel or almost any spyderco FFG, but they sacrifice attributes strongly in other areas - lock strength, tip strength, lateral stability in the pivot area and general overall toughness as a whole. I don't need to go to the CS forum cos i'm not a CS fanboy, i'm simply being realistic. For the price, show me a knife that will beat a cheap Code 4 hollow ground spear point in strength, materials and performance, i asked this question ages ago but still got no answer, people just keep saying im wrong. It's easy to excel at one or two things, like cutting ability and steel choice, but as a whole, for a knife that covers all attributes really well without sacrificing much at all in any area, CS offer some serious performance for the price.
Enjoy your knives, and your opinion. Just don't be upset because others don't agree with your opinions.
Thanks.
You are reaching so hard to try and make an argument, what am i supposed to do mate? copy and paste the exact same words the entire thread just to make sure i've kept the identical statement and avoid people like you nit picking at it like someone who trips someone up for bad grammar in an argument? All i've done is try to reiterate what i've said in different words so that ignorant eyes can see my point as well as raise new points. Take it as you will, I've said nothing that is false, pretty sure deep down you know that, but it's just not your flavor, or you just aren't a fan of certain knives.
You keep inferring that people are "ignorant" because they don't agree with your opinion. Please stop that, it just makes you look bad.
I'm not sure how you can blame "bad grammar" when you're essentially moving the goalposts because you know full well there are plenty of knives out there which are just as good or better than CS knives. Come on, now.
What? No, it isn't. Lord, this is getting deep, so I'm bowing out.
OP, sometimes it is best to use the "ignore" function so as not to be derailed or hijacked.
In line with the new theme, I will state that if I had to pick a single folding knife for reliability in a critical long-term and/or emergency situation, it would be one of the newer G10 XHP Cold Steel folders. High quality blade steel, strength, materials, f&f. I say that from a position of owning 95% other branded knives. Cold Steel strikes me as the superior product-for-price deal in pocket knives at the moment.
Well, in conclusion of this thread, different strokes for different folks 😉
Have a wonderful rest of the day people
I don't mind the tangents at all. Discussions are organic! Besides, I'm a positive guy and appreciate everyone's viewpoint. In fact, I learned some stuff myself, though most of it confirmed what I already new about CS. Unfortunately, I will probably still be touching base with Lynn about this thread, just get his take on it.
My guess is...Let's put it this way, Lynn won't exactly be in love with some of the stuff that was said on this thread. In fact, he'll probably be pretty red-assed about it. But Lynn is a professional and will turn it into a learning experience for both his company, his customers, and his critics. All have something to learn.
that all you could eat rib buffet...come on your heckling Lynn, right? you aren't being serious that this is what happened?
that aside i love the simplicity and sheer brilliance in the drop forged one piece line in the 2017 new offerings. i will be buying a couple of those and testing them out.
Yes, it happened, but it wasn't all-you-can-eat. It was advertised as "eat-till-you-drop", but they discouraged people from going back for seconds to avoid having customers bellying up and spending the entire day there. You needed to eat your fill in one shot. The place is long gone now, so we'll probably knock around town looking for bison burgers or steak nachos when I'm in Vegas, like we usually do.
And I agree about the CS products, obviously. There's never been anything like the 2017 lineup, but that's just my humble opinion.
Guess what? No one here is concerned. What sort of comment is that to make? "I'm going to tell Dad you were talking about him when he gets home!"
When you talk to him, make sure you explain what actually happened. "Hey Lynn, I went into General and made an "Ooh-rah For Lynn!" thread and some people said unkind things about you, and disagreed when some other folks said your company's products were the best." I mean, really, that's what happened, right? You started this thread here where people are under no requirement to say nice things about Lynn or Cold Steel, instead of in the Cold Steel section where it would have gotten comments more inline with what you were expecting.
I am not sure how this thread is supposed to be a learning experience for his critics, because there's nothing to have learned here. Well, ok, except for your assertion that he can't use the Internet and that forums mystify him.
When you talk to him, make sure you explain what actually happened. "Hey Lynn, I went into General and made an "Ooh-rah For Lynn!" thread and some people said unkind things about you." I mean, really, that's what happened, right? You started this thread here where people are under no requirement to say nice things about Lynn or Cold Steel, instead of in the Cold Steel section where it would have gotten comments more inline with what you were expecting.
Come on, this is not really necessary. The OP is not being confrontative, and we always have something more to learn, nothing wrong about that. You've stated your opinions, and he has his, no need to be so confrontative.
Personally, I find the idea that he felt the need to let us all know that he intended to let Lynn know that his thread wasn't full of accolades to be confrontational. It felt more like an admonishment to those of us who didn't agree that Cold Steel products are the best, and that Lynn's a great guy. Your mileage may vary. I'll allow that maybe I'm misreading his intent, however that's just how it comes off to me.
Instances of Lynn Thompson acting like a dirtbag: Too numerous to count.
Instances of Lynn Thompson not acting like a dirtbag: One; thanks to this thread.
Score so far: Lynn Thompson = dirtbag.
He dosen't need to be nice family guy fluent in every aspect of life for me since his company is selling good knives for the price. There are some other CEO's who are douchebags and nobody complain so much about them.
My opinion, not that anyone cares so dont attack me, is that Cold Steel is my favorite brand for folders.
I also own a large number of ZT, Kershaw, Benchmade, Spyderco, Reate etc so im not exactly a hardcore fanboy. Comparing to other high quality brands, I DO personally think their new 2015 product(and beyond) has some of the best value for the money. American Lawman for example, you can find it for around $75 with XHP steel and G-10 that's the same quality as the Paramilitary 2.
Also, MY OPINION after owning other high end production folders is that Cold Steel's quality control is on par, or even better. For example, the latest Benchmade 710 and 908 i received cannot compete with the Swift/Ultimate Hunter and other 2015+ CS offering in terms of fit and finish. However they are more expensive while having less "premium" steel.
Regarding their customer services, i think that they could do better on the email and web form front. However, from my experience the customer service over the phone has been great. I have had 4-5 warranty returns with CS over the phone(or sometime i just sent it in with a note), and each time the turn around for getting a replace has been less than 2 week from the day i shipped my knife out. Part of it is probably because i live in Socal so the shipping time is fast.
For perspective, here is a list of popular/high quality knives i own from other brands, so my opinion above is not based on just hype:
Kershaw/ZT - 0350, 0560, 0200, 0301, 0562CF, 0801, 0909, 0630, blur, knockout, link
Benchmade - 710, 940, 810, 908, 950, 551-1, 550-1, HK 14715, Adamas
Spyderco - PM2, Manix 2, Yo2, Milie, Endura, Gayle Bradley 2
Reate - Hills, Horizon C
