- Apr 1, 2009
I had a bit of a play with a cheap Chinese VFD on a Chinese hammer a while back. IIRC it was a new 25 kg (55 Lb) Anyang hammer with a 4 kW (5HP) motor, going to someone who did not have a 3-phase supply and the VFD was the cheapest way of getting 3-phase power. The variable speed seemed to make it more controllable for delicate tappy stuff, but I got the impression it was a not-unwelcome bonus, rather than a reason to use a VFD in itself.
The motor pulley was correct for a European 50 Hz supply and trying to push it any faster overloaded the motor/VFD combination. Turning it down to about 40 Hz for the delicate stuff seemed about as low as was realistic. Bear in mind that Kinetic energy varies as the square of the speed so 80% speed equates to roughly 64% blow energy. The reduction is in addition to the control provided by the hammer itself.
I'm (only) fairly certain a VFD without a clutch would not work well. Having to spin up the entire machine/motor system from standstill is a lot different to "just" having to spin up the machine with the motor already at full speed.
