- Oct 20, 2008
You probably wouldn't want to use babbitt... since large roller or ball bearings can be found pretty cheap, used. Babbitt was an expedient way to fit bearings into cast shells, and if you're fabbing a hammer, it would be easier I think to just use bolt-on bearings. Babbitt bearings are also pretty messy unless you have a reservoir underneath to catch oil, like on a lathe.
Other than that, I'm sure the only impediment would be sourcing heavy components at a low enough price. If you have a good scrap yard nearby, this may not be impractical...
Me too! Nothing would be cooler than running a real steam hammer with boiler. From what I gather though, as a one man operation, that's a dangerous and/or technically challenging proposition, and includes a lot of secondary considerations such as conditioning the water before piping to boiler- not to mention the archaic technology one would have to master to build or overhaul such a boiler and system.
Yep, that actually sounds like an absolute blast! In a good way, not in a bad/steam explosion/front page of the paper way...
I'm always tempted to use one as an excuse to build a big steam generator though, be boss as hell to have a steam hammer running on a wood fired boiler, or whatever the correct nomenclature is.
