shane :
As I suspected from your eply you are not a knife maker.
Which is a public and well known fact, there isn't much of suspect.
Espirit light baisting thread, stated in an earlier review and referenced in posts.
Cutting it measures push cutting sharpness, influenced slightly by geometry.
The statement from the review :
"The NIB edge sharpness was a little less than optimal scoring 207 +/- 22 g on light thread. A blazing sharp finish can approach ~100 g."
Optimal would have been a more precise term. Most high end production blades like Spyderco and Cold Steel have this level performance. It is when the blade starts to be able to shave hair above the arm.
Colorful terms like blazing are used on occasion, mainly for illustration. Like "the knife parted the rope like water". This of course isn't an exact description, blazing sharp doesn't really meant the knife edge is actually on fire.
They are used mainly to give some context to the numbers and such, and to make the reviews a little less dry.
You use the term "decent" alot...but for different analogies?
It generally means average, performance which you would not rate a negative or a positive. Reviews generally contain very subjective elements along with the stock work. It is mainly for perspective and only useful in comparison.
The Camp Tramp for example works decent as a brush machete on woody vegetation, it doesn't have the length I find optimal for such work (12-14 inches), but isn't so short that you heavily suffer power or reach for limbing.
If you go any smaller, you start to have to bend far too much, and you can no longer chop off branches without requiring multiple hits a lot of the time. Yes a lot of this is vague and subjective. What is decent to one person is horrible to another.
Some of the early reviews didn't have any of this type of commentary in them, it was added on request. There are less subjective performance descriptions for those interested.
You compare the edges of a Tramontina Bolo to a Camp knife?
Yes, as the scope of work overlaps to some extent.
The Tramontina is made to be sharpened with a file for jungle use..
Many "jungle" natives do not use a file. Stones are common in Malyasia for example, and the blades finished honed on a fine stone, not sure of the grit of the stone, the maker didn't know it, just started that two grits were commonly used coarse and fine. It could be raised to a fine shaving finish with some stropping on leather, so I would assume something beyond 1200 DMT. The stropping was generally done just for cutting palm fruit, the parangs for general work were generally left with the fine stone finish (far beyond 600 DMT I showed the maker my hone) and would be sharpened once a week. If you want a sample of the stone I can give you the contact information for the maker.
A machete sharpened to a 600 or better grit will dull in a heart beat! It was not made for such a fine edge!
For the comparison referenced, the blades were chopping wood. For such work very coarse edges don't penetrate well (its just push cutting) and they degrade quickly and you lose a lot of metal as the microteeth break off. I initially used the Tramontina with a file and a butcher steel, this is noted in its review. But later I switched to various hones. The aggressive finishes however can be of benefit on some soft vegetation as you are doing slicing work.
It became immediately apparent that you use no consistant mean of medium for testing.
You use different things for different aspects of performance. You would look from one review to another to check for consistency in materials. If you do this you will note this is true to some extent, but the reviews are evolving. Some of the stock tests are only recent.
You mentioned light thread,3/8" hemp,phone books,hard wood dowels....and newspaper...where is the attention to detail here.
The specifics of each were given usually in the first review they were mentioned, which usually went into detail on method. I did intend to have a page on the specifics of the testing which would be linked to in the reviews, and a rough draft was written, however I never kept it updated. I am actually doing that now, but it will take some time before the reviews are all updated to reference it.
The hardwood dowel is a one inch round piece of basswood by the way. That test is quite problemative as it is very dependent on my strength, and I got significantly stronger as I did it often. I have to go back and update some of the older reviews as I recently retested some of the blades and the performance has changed significnatly for this reason.
What exactly is a high polish?
Generally above 600 DMT you start to lose slicing aggression quickly and the edge is more polished than aggressive. In the reviews it generally means very fine ceramic, which approachs the finish of CrO.
Once I read that you were comparing a Swiss Army knife to a Camp KNife to a Tramontina Bolo I began to wretch. What's the idea?
Guaging scope of work and relative performance in various areas.
Are you trying to prove that a very thin edge cuts better than a thicker one?
No Mike Swaim already did that on rec.knives many years ago, and also investigated the effect of various grit finishes. Joe Talmadge extended the work and made specific numerical comparisons before and after. This is referenced in several of the reviews, and many posts I have made in this area.
I have never claimed to originate commentary of these aspects. Neither did those two individuals, Mike however discovered the effects independently, though you can find older references. Alvin Johnson also talked a lot about the effect of edge geometry on cutting ability on rec.knives in the 90's in rec.knives.
Are you going to compare a filet knife to a chainsaw next?!?
Probably not, there isn't a lot of overlap there. Phil Wilson has chopped through a 2x4 with one of his fillet knives though (a test of toughness mainly), you could ask him if you are interested in how efficient it was compared to a chainsaw.
Back to the rope cutting :
I also forgot to mention, that besides being influenced by geometry, it also compounds the rate of blunting. Thus any difference in performance between two knives is elevated. As one knife starts to requrie more force, it then impacts the cutting board harder, as it does it now of course blunts faster (which makes it impact the board harder, which makes it blunt faster ...).
Thus the ratios for performance I have quoted in the past are artifically elevated, specifically if the blades were not used against backing materials, the performance advantage to the various blades (even of similar geometry) would not be as great. I am not sure of exactly how much of an effect this is, I should buy a couple of identical knives and try both methods to see.
-Cliff
