Nathan the Machinist
KnifeMaker / Machinist / Evil Genius
Moderator
- Feb 13, 2007
I don't think it's hooey.
I don't particularly like sharpening wet but I do it. It's messy and I had to find belts that work with it but I sharpen wet because I proved to myself that it makes a difference.
Anybody here who has a strong opinion on this subject who hasn't actually tested it for themselves should, it's very simple.
If you have several blades that are identical it is extremely easy to test it for yourself. There are two basic tests. The first one is obvious, sharpen two blades the same way but do one wet and one dry, cut an identical amount of the same media (identical cardboard) and observe the edge under bright light and magnification. Repeat it a couple times. This isn't rocket science.
The other thing to look at is "how far out of whack does my process need to be to cause a major problem". Use a slightly more dull belt than you normally use, dwell a bit slower, use a tad more pressure etc. What happens in a worst case scenario if your technique isn't quite up to snuff on a particular blade. This one was the big eye opener for me. Running a used 120 ceramic at 1000 SFM, simply allowing a hair more heat than I normally do caused soft areas in the edge running probably a full millimeter up into the blade, so not only was the edge damaged, the blade was damaged. My fingers weren't burnt and there were no colors run to warn me I had a problem. And this was in D2, which stays pretty hard up to over 900F. This was eye opening and why I won't risk grinding the edge in dry because it's really easy to screw it and not even know it.
Can grinding the edge in dry be done and work reasonably well? Unless you're talking about sharpening razors, of course. Is it a reliable high quality process? I proved to myself that it is not.
If a person grinding their edge in dry will try these two very simple tests on their work they may learn something. The entire test doesn't take an hour from start to finish. It just requires some objectivity, a light source and 10X magnification.
