I used to use a belt sander with 220 or 320 grit belts followed by leather power stropping, and recommended it frequently. On and off over the years I got odd behavior from various blades. I finally traced it to power sharpening. After seeing the loss of performance on a few knives, I can no longer recommend it as a good way to sharpen. The knives I'm talking about were rather large, showed no color on the blades, no heat to the fingers, yet dulled quickly and dented on small branches. This was on a wide range of steels from 1055 to A2, and once on M2 that I'm not quite sure about. When I used the sander to thin the edge, but didn't let it get right to the edge, then finished by hand sharpening, I found the same 1055 and 1095 blades would cut all afternoon and still shave my arm, and make it through a couple of 2x4's or a pressure treated 4x4 without noticeable dulling. I mention these 2 steels in particular as they're the most susceptible to heat. The study mentioned was further expanded upon by later testing and found a loss of 5 points of hardness, maybe more. I don't remember the alloy, but it wasn't a plain carbon (10xx) steel.
