- Mar 10, 2002
So a fully hardened blade would resist bending by about 25% more before it snapped?
Would the soft spine on differentially hardened blades allow the edge to crack without having the blade snap in half
While my yearling was not designed to cut bone, it is capable of it if the need arose. Would the steels you had in mind, that can be made harder and more wear resistant, accomplish this as well?
IMO, more important than the steel of choice, is the smith's undertanding of it's properties, and his ability to precisely control them. Do you think that the specific steel used will make a bigger difference than this, assuming everything is done properly?
Based on the amount of torque that it would require to break a knife I can't help but feel that whatever part of the broken knife that is left in your hand after it breaks would be very hard to control and keep from cutting yourself or someone else.
Not to mention any of the fragments that will become airborn after the big snap! Bending sounds a heck of a lot safer to me.
Another point is that a bent knife can be straitened ...
I have broken lots of knives by prying, just recently snapped three Deerhunters, one multiple times. This isn't usually a problem. Your reaction to the break is usually very quick. Plus of course you make sure you don't stick your leg or whatever right until the blade .
For example of what use is it to have the knife flex past 90 degrees, or even that far for example. By that point it isn't being a prybar anyway. The mechanics turn the vast majority of the force away from prying
Ideally for a safe and effective prybar the knife should be maximally stiff while being able to bend to around 45 degrees and have some give before it breaks. What is of most importance is knowing what it can take, so have this clearifed by the maker so you know how far to go before the blade will either take a set or break. It is the same as any other performance consideration, how much care does it need not to rust etc. .
Note as well that how much you can bend a knife is strongly dependent on the thickness. The thicker the knife the more strain it will taken at a given angle.
that's a dealOriginally posted by Jose Reyes
If that drinking contest is open to collectors as well you can count me in...
At this point, considering the fact that you've never even tested one of Ed's blades, your opinions are just generalizations based on the inherent qualities of different types of steel. -Jose
Originally posted by lifter4Him
This is really an apples and oranges discussion.
You wouldnt use a flyrod to fish for tuna
You are talking about testing or experimenting in a controlled environment. I was thinking more along the lines of uncontrolled real life experiences.
Would you honestly not wear saftey glasses when you perform one of your flex/break tests that you were talking about?
Therefore a Fowler knife will continue to be a prybar well beyond 90 degrees.
I'm having a hard time picturing your suggestion about the two pieces of wood...
That requires a lot of trust in what the maker is telling you.
Wouldn't it be benificial to have the blade etched so you could see what HT it has been through and know for sure what it will and will not do?
You mention steels that in your opinion are better suited, under specific circumstances, than 52100. Yet every example will have it's own deficiencies when compared to 52100.
No I have not used one. There is too much of a difference in performance between us. For example the spine is left very soft and the tapers extreme. This isn't a matter of right or wrong simply a difference in where the performance should be focused.
