stjames
Sebenzanista
- Oct 26, 1998
Thomas Linton said:Ah, another devotee of St. Sebenza of Blades.![]()
That is St. James of the Sebenzanistas, my son.
stjames said:That is St. James of the Sebenzanistas, my son.![]()
Cliff Stamp said:Before arguing if folders "need" lubricant or not from Mike point of view, you would first need to ask Mike what he requires behavior wise, and how he uses and what he values in performance.
Using knives in very dirty conditions for example most if not all oil based lubricants tend to make the situation worse as knives become near impossible to clean because you can't rinse/flush out dirt.
If you want knives buttery easy to open it is hard to achieve this without lubricant, but this is very difficult to maintain on working knives so it isn't difficult to see how someone would not value that at all.
hardheart said:I oil frn handled working blades, since that crapola tends to embed itself into the frn around the pivot and makes it gritty. I don't like teflon washers because the same will happen. I prefer metallic washers, which I find a little easier to clean up.
Allright, I'll go on record as saying KY is the best.
I think he might be talking about fixed blade knives. It's true it is useless and a waste of time to lube your fixed bladed knives, and furthermore to all those idiots ruining there (FB) knives with all them new fangled oils, greases, dry lubes etc. I concure "quit lubing your kniveses to pieces"!mike_mck2 said:It's true, most knives do not need lube. Just a good cleaning, and that's about it.
Quite a few lubes on the market not only are not needed, but they actually increase the wear & tear, because they gum up and collect dirt/dust/debris, even when used sparingly, and most seem to be applied quite liberally.
I have explained this to numerous people, and they just do not understand.
I try to tell them, if it's not broke, you won't hurt it by not fixing it. Don't lube it unless it just absolutely needs it, and even then use very very little.
Yeah, I once tried lubing up a knife (to pieces) trying to get the frigging thing to fold, then I realized it was a fixed blade. I felt bad because of all the premature wear and damage I caused it.zman said:I think he might be talking about fixed blade knives. It's true it is useless and a waste of time to lube your fixed bladed knives, and furthermore to all those idiots ruining there (FB) knives with all them new fangled oils, greases, dry lubes etc. I concure "quit lubing your kniveses to pieces"!
digdeep said:I generally use Militec-1 on my knives but was wondering if there is any problem with damaging the scales like cocobola, walnut, or micarta if accidentally put on them?
NeedleRemorse said:Actually, lubricants ARE necessary on many fixed blades. 01 blades for example need to be oiled to prevent rust. So even if it's not for the purpose of preventing wear on moving parts, you're still using a lubricant.![]()
I'm sorry, I was just trying to be funny. I think the bottom line is that just like anything else in life there are no absolutes. Maybe Mike mck2 has found that he needs no lubricant in his "folding" knives and that his friends use too much which in there cases attracts contaminants which inturn will tend to promote premature wear. I myself have found that small amounts work best. But nothing at all is counterintuitave to me. That's just my two cents. AZ...NeedleRemorse said:Actually, lubricants ARE necessary on many fixed blades. 01 blades for example need to be oiled to prevent rust. So even if it's not for the purpose of preventing wear on moving parts, you're still using a lubricant.![]()
KeithAM said:Just for fun, here's an incomplete list of manufacturers who recommend lubing the pivot...
Cliff Stamp said:You can generate a huge list of makers/manufacturers who will promote sharpening at 20 degrees per side and in general support a great many knife myths. Popularity in general doesn't make an arguement.
-Cliff
