- Aug 21, 2014
wheres the chalk?Nah do you...
Sometimes I wear shirts 2 sizes too small for entertainment!
We are keeping this family friendly hahahahawheres the chalk?
You old couger you!
Is that a cross between a codger and a middle aged woman looking for a hook up? I guess I really am gender fluid.You old couger you!
That grinder may be available for a song next year if things around the world continue in the current directionGo for the 70K grinder if you can swing it, even though you may feel that you do not currently have enough big projects to merit that purchase. Naturally a couple of preorders or just one for something special like the I.D will raise the required capital and then some at the snap of your fingers but being so close to the end of the year, you may have decided that a much larger 1099-K issued by PayPal in 2022 may not be the way for you to go, depending on how you keep your books. There are several other relatively easy ways for you to raise that 100K if you don't wish for it to count as "revenue", without mortgaging the Mothership. Just saying.
Sporks because in a tactical situation you don't know if you'll have to fork or spoon.I'll bet there is a good market on tactical spoons
You know sir..... begins with daggers ends with can openers..So now the question becomes, what do I do with all the steel that I ordered wrong
Troof
Tactical chisel. D3V allows it to be used for opening paint cansTactical screwdriver?
The only correct answer is “Daggers” of all sizes haha.So now the question becomes, what do I do with all the steel that I ordered wrong
Very close, Westley. However, the correct answer is:The only correct answer is “Daggers” of all sizes haha.
I'm confident that I could design something pretty amazeballs with that blade length in that thickness...So, I mentioned before, I messed up when I ordered the steel plate for the Kukri project and the plate is sized for the blade in the wrong orientation with the material grain running perpendicular to the part. I can fix this by changing the part layout in the sheet, which makes the sheet size larger and gets one and a half more blades in it. (we're going to have a special: off spec Kukris, half off) <----- that's a joke.
Which isn't great but it's a fix. But it's 16.5" and my 16X32 grinder can't deck the new larger sheet size. I've been wanting the next size up auto grinder and I've found what looks like a good used grinder, but it's about $70K. Which is steep just for this project and we really don't need to run big stuff like that frequently and I already have a bunch of automatic grinders here and I'm starting to think I just screwed up and I should just bite the bullet and order more steel instead and order it right this time and then I'm wondering what the hell do I do with this incorrectly sized steel because its's really thick and what do you make with a 6" blade that's 5/16" thick and then I got thinking about daggers again....
this has been a long week
