not even to shut up once and for all guys like me?Why haven't we built this?
Simple - we don't need to.
We don't need to build it because we literally prove it many thousands of times a day - all sorts of transportation, engineering, navigation, etc. is based on calculations of the curvature of the Earth, and if they were wrong, there would be consequences that would force us to change those models. It's kind of like saying, "we need to build this thing to prove gravity." We prove that gravity exists millions of times per day, and in all sorts of different ways.not even to shut up once and for all guys like me?
It won't shut them up. Because none of the proof that already exists has done that. They'll just grasp at some other straw. The phenomenon of people stubbornly clinging to their beliefs in the face of fact is just as well documented as a round Earth is. And almost as old....how awesome would it be to build this and shut people up about it once and for all?
"All the people?" Really? I think that's what happens when you spend too much time down a rabbit hole and don't come up for air - you start to believe that a relatively tiny group of people somehow constitute a widely-held view of the world....with all the people questioning the globe earth model you'd think we DO need to build it.
I agree - that's one problem. But another problem is that too many people don't believe stuff for which proof already abundantly exists. Cognitive disconnect cuts both ways.the problem is that too many people believe stuff without proof.
Have you ever been to a really big, open, relatively flat part of the country, where you can see for a lot farther than just the two miles suggested in this so-called "experiment?" How about, for example, a stretch of perfectly straight highway across the Mojave desert, or sections of Hwy 50 in northern NV, that has a row of power lines along it? If so, why do you think those poles appear to get shorter as you look farther down the line, miles ahead? And that they continue to do so as you advance in that direction? That is literally proving the exact same thing that this guy is attempting to say remains unproven.
How would you explain the Coriolis effect, if the Earth isn't round and rotating? It's an honest question.
let's start a collection to make this happen
*I'm not a flat Earther, BUT.......I think the problem is people are generally getting sick of being Lied to from our media, and from our institutions.We don't need to build it because we literally prove it many thousands of times a day - all sorts of transportation, engineering, navigation, etc. is based on calculations of the curvature of the Earth, and if they were wrong, there would be consequences that would force us to change those models. It's kind of like saying, "we need to build this thing to prove gravity." We prove that gravity exists millions of times per day, and in all sorts of different ways.
Is 50 miles long enough? I've got a green laser rated for thatThis does make me think of an experiment that a person could do to prove that a earth is flat or round
Maybe somebody could check me on this one and tell me if I'm thinking about this right
You could use a master precision level and a laser beam on a tower above the ground high enough to reduce ground level refraction (the mirage effect) and set that laser beam to be shooting as perfectly horizontal as possible towards another tower some large distance away. Another level at that distance would be referencing the Earth slightly different. It would be slight, but it would be meaningful and significant and reproducible. That laser would hit that tower at a spot and you set up another laser at that spot and shoot it back to the original tower. If the Earth is flat that second laser will shoot straight down the first laser. But if the earth is round the second laser will be elevated.
This should be simple enough for some flat earther to actually do.
If I'm doing my math right, the earth curves about 66.7 ft in 10 miles. So you could shoot a laser out to a tower at 10 miles and then shoot it back and it should raise 133 ft
If I'm doing my math right, this is .0012" per foot on the level. Mine is good to .0005" per foot. So it actually should be possible to do this.
