I was a bit surprised by that 3 point call Jimmy got , but it was a good game (butler did not look the same)Glad to see the Nuggets finish it off tonight. Well done in a tough game.
He's his own best friend?
It's still little bit chill
Do you personally still prefer the Delta 3V?Cruwear will not have better corrosion resistance than Delta 3V
Delta 3V is not like regular 3v. There is much more free chrome. Enough that it is practically stainless. I have a blade that I threw in a stump a long time ago and it doesn't have a speck of rust on it.
Our Cruwear will have less free Chrome because it has higher carbon that's going to compete for some of that Chrome.
The higher carbon also makes it more susceptible to retained austinite which limits how much carbon I can put into solution which ties my hands with aust temp much more so than 3V (if using a low temp tweak). Those knives in the picture above, they all rockwelled about the same. The one on top has RA. The one on the bottom is an industry standard control exhibiting the typical crumbly mushy edge of the high temp. The one in the middle is nicely optimized. This optimization is not just time and temp, there are other important variables.
Although Delta 3V is quite tough, I have not been able to coax good edge stability out of it at higher hardnesses. Cruwear should give me another point or two anyway and actually be tougher than 3V would be at that hardness.
We race 4V at 64 regularly. It has low corrosion resistance though. But it has very superior edge stability for a complex steel.
We're in pursuit of better edge retention in a durable knife. That has always been the focus. And we understand that edge retention is not the same thing as wear resistance. At least not how it is measured in industry, which has little to do with a normal cutting tool. Edge stability is key and a strong uniform microstructure wins the day over secondary carbide volume fraction. Obviously.
