Richard338
- May 3, 2005
Light weight, baby!!Feel kind weird, today, as I weighed in at twelve stone and a half.
Not bad for somebody who stands four cubitsFeel kind weird, today, as I weighed in at twelve stone and a half.
Got you beat by 5 lbs, I mean a couple of kilogramsFeel kind weird, today, as I weighed in at twelve stone and a half.
dumb why cant they just be the same. I refuse to do itSome people use the 0.0393700787 conversion factor which is retarded
I use the 25.4
25.4 is more accurate (perfect precision) and simpler. You just divide by instead of multiply
For approximate measurements, you can just use 25.
Making conversions in your head is easier this way. To go from English to metric in your head, you multiply something by 10 (add a zero) double it. And then add half again more.
Example: 8 inch in millimeter is 80 + 80 + 40. 200 mm. Anybody should be able to do that in their head. The real number is going to be a little bit more but for an approximation it's going to be very close.
did they some archaic stupid measurement that ends up just being a percentage of pounds?
I wish we would just convert to metric, but I doubt it will ever happen.
It would be painful at first, but long term I think it's a better system.
divide and conquer?And there's another problem. Some people drive on the left and some people drive on the right
No standardization on things that could have been easily standardized
Kg to lbs is just x2.2.I always SAY that I love the metric system, but it's such a PITA converting kg to lbs while doing a hard workout at the gym. I'm so programmed that I STILL need to see my weights in lbs to understand what I'm actually lifting at a European gym for several months. By the third exercise I can barely do the math-- and it isn't even hard...
Km to clicks is my kind of math. Lol
The origins of that are archaic, and just like Standard vs Metric, the main reason for resisting change, is “We’ve been doing it this way for a long time. Too hard to change”.And there's another problem. Some people drive on the left and some people drive on the right
^^^I understand your method but parenthesis and units matter.Kg to lbs is just x2.2.
Easiest way to do it in my head:
X kg = 2X lbs + 0.1X lbs
95kg = 190lbs + 19lbs =209 lb
I think lack of standardization on lots of things comes from an absence of planning/foresight or an attempt to corner the market.
