- Sep 4, 2011
What clear are you spraying, specifically, that’ll hold up to abuse that guitar bodies usually see? Do you spray HVLP?
Will having that many layers cause problems with durability, or does it go on pretty thin?
My favorite clear gun for production work is a SATA 5000 RP with a 1.3 needle and fluid cap (silver) i also use a SATA 5500 RP with an I cap and 1.2 needle and fluid cap (gives really nice results but is slower)
You generally do not want to build layers of clear like this bad things can happen... solvent issues (trapping it, can lead to small bubbles, adhesion problems, die back, etc) and too much clear can even cause it to crack
In this case I'm using the clear almost as a filler that I can sand down and create a flat smooth layer of the final 2 coats of clear (I'll be sanding a LOT off!)
