- Apr 27, 2016
Hell no, no warrantyDoes it come warrantied against breakage? No? Then probably not.![]()
You and me both. Cheers to self restraint in the new year.
My niece just had her Air Force drop night and was excited to be assigned to the AC130 which was her top choice for whatever reason.
Pure badassery. Thatās whyMy niece just had her Air Force drop night and was excited to be assigned to the AC130 which was her top choice for whatever reason.
I wonder if I could trade a CP4 for a chopper?
Iāve always used Hotshots EDT every fuel up. Iāve been meaning to look into the Archoil because there has been some documentation that it actually prolongs times between regeneration.I use Archoil diesel fuel additive in my diesel fuel. You really should be using something with a lubricant package if you have a CP4 pump and this fuel additive doesn't harm the diesel exhaust filter, it has been demonstrated to be good for it. You maybe should look into it.
Bring the rainMy niece just had her Air Force drop night and was excited to be assigned to the AC130 which was her top choice for whatever reason.
Itās the design that can fail catastrophically and can cost $10,000+ to fix. It the same nonsense that Ford used on certain transmissions that caused early wear that killed the transmissions, only on a larger scale. To save a few pennies they put the customer on the hook for thousands. Iāve had more Fords than any other brand, so Iām not by nature a Ford hater.Problem is itās not really Fords problem (in my belief), The CP4 is on millions and millions and millions of cars in Europe and they donāt explode. The USA has stricter guidelines on the ULSD so it actually has even less lubricity in it then ULSD in Europe.
P. I. N. T. O.Itās the design that can fail catastrophically and can cost $10,000+ to fix. It the same nonsense that Ford used on certain transmissions that caused early wear that killed the transmissions, only on a larger scale. To save a few pennies they put the customer on the hook for thousands. Iāve had more Fords than any other brand, so Iām not by nature a Ford hater.
They were both to blame on that one. As were the owners who never checked their tire pressures. Lots of blame to go around.Oh, and lets not forget the Explorer/Firestone tire fiasco...
Iām also a staunch believer that Americans are lazy. Change your fuel filters every 15k miles and most CP4 explosions likely wonāt happen.![]()
Anyone taken one apart?I don't understand how a dirty fuel filter leads to dirty fuel
I can see how a dirty fuel filter would lead to reduced fuel flow and eventually a stoppage
But I don't understand how a filter with a certain micron rating is going to lead to unfiltered fuel getting past that filter unless it is bypassing.
Serious question
