- Apr 27, 2016
It’s not a dirty fuel problem. It’s not enough fuel getting to the pump, which causes it to overheat. That’s part of the recall on the 2020-2022 trucks, they are changing the programming on how it uses fuel to cool the pump at the same time. It supposedly started from just bio diesel because it goes bad quicker and can grow algae. It’s also a lubricity problem because the bearing can wear and it is causing the pumps to disintegrate. Ford supposedly fixed it with the CP4.2 that is actually in the trucks now by putting a pin in the bearing assembly so if it does fail it doesn’t explode and send metal and bearing pieces throughout the common rail.I don't understand how a dirty fuel filter leads to dirty fuel
I can see how a dirty fuel filter would lead to reduced fuel flow and eventually a stoppage
But I don't understand how a filter with a certain micron rating is going to lead to unfiltered fuel getting past that filter unless it is bypassing.
Serious question
At the end of the day it’s honestly luck of the draw like anything else. Your truck might have a good pump, or it might explode.
