Random Thought Thread
We lost power here TWICE today. It's this kind of bullshit that burned up our beloved shitty shitty Kia. Fortunately the Moris are okay. Because they're Japanese. And Japanese stuff doesn't just burn up for no good reason.
Thanks, we are, but it is hard on the machines. I hope you guys fare well tonight.
May want to look into a UPS, or at least some sort of whole building surge protection.
I guess if you limit the time it's on. I "think", if you run it full time, you'll get about a week based upon calculations I've done in the past while ruminating on it.
It's not an inexpensive solution, but my wife (and dog) would certainly love me more if I decide to just go for it.
Also a consideration to have both, whole house AND the small ~2-3kwatt inverter generators (Honda and Yamaha are the gold standards, but I've heard the Predator gennies are decent and ~1/2 the price).
Those things are a lot more efficient for lighter/smaller loads, especially if you rotate their use for necessities (when you have no idea how long it msy take to restore power). Eg. Use it to power the refrigerator for an hour or 2, then a separate freezer for an hour or 2, to preserve the food in them vs burning fuel to power the whole house. The bigger the generator, the more fuel it tends to burn while running, even with little to no load.
You can increase your power utility/efficiency even more by pairing the generators with something like Sensorpush temperature sensors. You can purchase the sensors and use them with any smartphone via Bluetooth. Stick 'em in the fridge/freezer to monitor the temperatures.
Each battery powered sensor continually logs readings (every 30 seconds?) and retains the logs internally for a rolling 2 weeks or a month (can't quite recall). You can even setup the SensorPush app in your phone to sound an alarm (as long as the phone is within Bluetooth range) if the temperature or humidity readings exceed your chosen alarm setpoints.
I wound up also adding the Wifi Gateway. As long as the Gateway has power and the Wifi is working, I'll get alerts/alarms anywhere my phone can receive data (eg. If the fridge/freezer door is inadvertently left ajar and the temps climb above the alarm point, my phone will sound an alarm/alert while I'm out, at work, or even if I'm out of the state).
You can move these around and log different things, eg. Just how long it takes to cool the internal temps in the freezer to X, and how long it takes the temps to climb back up to XX, so you can optimize the power rotation/cycling for maximum fuel efficiency during an extended outage.
Headline today:
Cougar kept in NYC home illegally headed to Arkansas wildlife refuge
So many possibilities.
Why is it illegal for an older lady cruising for young beef to head to an Arkansas wildlife refuge?
Did the home owner get tired of her?
I'm lost.
TANGENT BELOW
A pringles can reminded me that I need to buy new pants when I reached into it to get the chips from the bottom.
Could also use a UPS for just enough time it takes to shut the machines down safely - that should be cheaper. Just a thought (that what we do for server farms, etc.)
Yes, and the nice thing is if the outage is brief it will get you through. We spent $160k to protect our computer cluster. We have saved a lot of aggravation since then.
Rated power says 65kVA, but the math actually works out to 72kVA. Either way, it's a good amount. For a UPS, would want to oversize to something like 100kVA/kW to ensure it can handle the motor inrush without tripping.
What he said. I’ve had a few too many margaritas with dinner tonight, but trust me, get some ups or three phase monitors at least. 😂
That's just one machine. There are five.
Oh wait... there are only four now....
