Ankerson
Knife and Computer Geek
- Nov 2, 2002
Ankerson. any news about PSF27?
Thanks
Very soon. :thumbup:
Thanks
With my experience with the listed steels, I'd say that the mt19 is better than elmax, 154cm, and s30v so in my mind it's at least a solid category 4 and likely above. Those are just my non-scientific thoughts. I have only used it at a 14k grit polished edge so I don't know how it will handle 400 grit.
I dont see how a 1.5 point difference in hardness is that critical (60-58.5). The hardness is indicative of some other cause; a symptom if you will.
Isn't the Rockwell C scale exponential?
As a whole yes. However, the range of the scale used for knives is very nearly linear.
I was mainly referring to the notion that 58.5 was nonsense, however I see that Daberti is in Italy and there may be a translation issue, and in any case my reading of his statements was probably too literal. I just didn't see a jump from fairly bad to pretty good with just 1.5 points difference.
What is the difference between say 60 and 58 in terms of compressive strength? How narrow are the categories in terms of cut-off from one to the next higher or lower?
There is something that would clarify many concepts about heat Treatment ,,,[snip] ...
As I explained more than once in this thread, HRC alone will tell you how much of compression strength you will get. But with some metallurgical knowledge and informative datasheets you will be told aust./tempering temps, and make your own whole picture.
That was my point, though it should have been made with much less subtlety. There is more than one way to the same hardness, and not all are equal. The difference in hardness is just a symptom of the real issue that is causing the same steel at 58.5 to behave differently enough to be in a different category than when at 60. Unless some sort of microstructural threshold is crossed, which can happen, I still don't think just increasing the tempering temperature 25-30 degrees for that 1.5 HRc drop will make that big a difference, assuming everything else was the same (hardening, quenching, cryo, etc.).
The increase from secondary hardening comes from 2 sources. First, as you said, the retained austenite is converted to martensite and then tempered during following tempering treatments. Second, the precipitation of carbides contributes to hardness. Those carbides, in stainless steels, are often chromium carbides and their precipitation will reduce the amount of chromium for corrosion resistance, while at the same time increasing hardness.
I can't help but think we are talking about 2 different things. Just raising the tempering temperature 25-30 degrees for a reduction of 1.5 points won't make a huge difference. Raising the austenization temperature the same amount can make such a difference, particularly with regard to retained austenite and how to get rid of it. You are also correct in terms of use of high tempering temperatures to reduce RA. Not everyone has access to cryogenic/cold treatments and some alloys are complex enough that cryogenic treatment won't be fully effective in removing/minimizing RA, so a high temper is needed. I don't know if the secondary hardening is really the intent, but the high temperatures for decomposition of RA may just coincide with the secondary hardening. If you can deal with the loss of toughness and corrosion resistance and/or don't have access to the cold/cryo, then high tempers are an option.
I'm curious to see the difference between PSF 27 and ingot D2 in Jim's type of testing. Not sure of the mules behind the edge thickness but as we know, it will effect the performance greatly .I hope it's in the 61 HRC range!
It will be up today, cutting with it and that S110V Manix 2 I was sent...
