Ankerson
Knife and Computer Geek
- Nov 2, 2002
Jim, do you expect to get that PSF27 blade tested for hardness?
Haven't decided yet...
I am completely satisfied that Cruwear, XHP, and PSF27 all have similar performance.
I've returned to using my B75P Mule in the kitchen because the S110V mule had issues when banged into cutting boards.
I guess wear resistance isn't my prime consideration in the kitchen...
My cutting boards are made of food contact grade high density polyethylene. If I sliced gently and carefully the edge stayed intact (no shiny spots) but if cut fibrous vegetables like carrots and the knife slipped and hit the cutting board then shiny spots developed. I'm getting balanced performance (stays sharp and has impact resistance) with alloys like XHP and B75P with the hardness above 60.What kind of issues so I know what to look for.
Also, it wasn't any of these glass cutting boards by any chance?
Your mileage may vary, no warranty express or implied.
Don't tell me. My s110v Native is also very easy to sharpen while everybody else complains how tough it is. Maybe I should do the carrot test on it as well?One question: did you have your S110V blade tested for hardness? I have a certain idea...![]()
Just the edge pro with its water stones. Nothing too fancy with diamonds or the like.What sharpening media do you use?
Now it could be that I'm just not skilled enough to tell when something is harder to sharpen. Afterall the s110v is my only supersteel I have. But how some people make it sound it should take hours to get sharp.
I would say that sounds very plausible but if its a systemic symptom then surely lots of knife nuts would have noticed that the super steel performs less than not super steels?Just take a look here http://www.bladeforums.com/forums/showthread.php/1168429-LionSteel-Steels?p=14029799#post14029799
Shortly: my idea is that you and Fancier are experiencing in flesh the common practices for highly alloyed supersteels in production made blades: ie. low austenitizing temperatures, no deep cryo= to much undissolved carbides and Retained Austenite= edge instability.
BTW: RA is easy to sharpen![]()
In light edc use edge retention on my s110v native is right between my 154CM barrage and my D2 Adamas. Both not really super steels.
For all the other guys I hope the S110v I got is a fluke. Or maybe it gets harder after more metal is removed?
Was considering that a couple of times. But wouldn't that leave scratches on my babies?Why not getting this http://www.flexbar.com/shop/pc/HARDNESS-TESTING-FILE-SET-26p5383.htm, I've just ordered one myself on their ebay store.
By no means NOT an ultimate hardness tester, but it could give you an idea of HRC of your knife and, known the steel, you could draw your own conclusions
@Fancier
But then not so super steels do better banging around? If so is that normal or would a differently treated super steel do better in the kitchen?Hmmm... Somebody might be putting words in my mouth. Both of my S110V knives cut cardboard like a dream, but my kitchen use involves more banging around and that seems to make a difference. I've found that the edge of the cardboard recycling bin (also plastic) is an edge killer during high speed impacts as well.
I apologize if you thought that of my post. I was just throwing my experience in the mix, not trying to discount anybody else's experience.Hmmm... Somebody might be putting words in my mouth. Both of my S110V knives cut cardboard like a dream, but my kitchen use involves more banging around and that seems to make a difference. I've found that the edge of the cardboard recycling bin (also plastic) is an edge killer during high speed impacts as well.
