Right on brother,
What's your opinion on diamonds?
Are there certain steels that do cut better with polished edges like skandivik or low carbide volume razor or AEL-B steel? Just wondering if there is a place for polished edges.
Nope.
At least not in my testing anyway.
Ankerson's not shaving his face or performing delicate surgical tasks, nor is he running a saw blade or chisel or chipper or axe, all places where a polished edge might be the best choice to produce the cleanest cut and resist the stresses most likely to be encountered in the task (wear of a different sort).
That said, high-carbide drill bits given a high polish last a lot longer than low-carbon cheapies (probably due to final Rc hardness after HT), a LOT of saw-blades use carbide bits sintered into place for improved longevity, and HSS chisels are popular as well for the high hardness they can be produced at. The only one I've seen pushing low-carbon steels into higher hardness ranges (>60 Rc) for use is Bluntcut.
So yes, polished edges have their place, but even then high-carbide may be the better choice, depending on use.
This notion of low-carbide steel performing better with a polished edge than high-carbide steel, is this an assumption resulting from difficulty achieving edges of similar quality in the first place? Low carbide steels generally polish more easily, right? Take less work? So people assume that the high-carbide edge has trouble getting there due to some inherent problem in the steel rather than it being a problem with their technique? (like sharpening a popsicle stick on a piece of sidewalk and then blaming the knife when the same treatment doesn't give it a similar finish?)
I've found this thread on ceramic knife performance and sharpening to be worthwhile: http://www.bladeforums.com/forums/s...-16WB-ceramic-knife?highlight=forever+ceramic
Of particular interest was a post by eKretz showing the result of trying to finish a high-carbide steel with inappropriate sharpening medium (too soft or dull to cut the carbides):
A low-carbide steel would likely have polished fine with the same equipment.
It is interesting to see how 2 knives - one in S110V and the other in S125V (all other things being equal) - will fare against each other... Any thoughts?
I think Jim had two Phil Wilson skinner knives tested in S110V and S125V - can you give us some details?
A s125v v/s s110v would be a test I would really be interested in. I have a PM 2 being annealed and re-hardened to 64 Hrc. As long as it doesn't warp I'd like to put it up against a s125v blade at 64 as well. I saw a Custom PM 2 with s125v at 63 Hrc come up for sale on BF production knives the other day. Maybe someone would like to test it against my 110 PM 2. I am in the process of having a s125v knife made but it will be a few months before I receive it. I just can't rap my head around the fact that s110v doesn't cut better than K390 or other A11's since 110 has all that Niobium (the hardest carbide former) in it. The only thing that I seem to understand is that niobium carbides are do much smaller than vanadium carbides and it's the vanadium that sticks out like saw teeth and does the most cutting. S125v has done the best in Jim's tests so far and I hope I fall in love with it when it comes in but I have this fascination/infatuation with s110v that I can't explain. I almost went with it over the S125v knife I'm having made because my head says 125 is better but my heart seems to want 110. I really don't understand that for sure!!!
But doesn't those 2 Hrc points account for them being so close?
From what I read they should be practically equal in edge retention, with S110V being a little tougher. I think Phil Wilson even mentioned in a post that S110V could be even more wear resistant than S125V...
I would say that this is a very comprehensive test on this knife. I certainly shows the edge holding potential of CPM S110V. This knife was pushed to the hardness and edge geometry limit and optimized for cutting abrasive materials like the rope and cardboard Jim used to challenge the blade. The hardness at 63.5 is about as hard as I can get this steel and still allow for a little tempering. Normally RC hardness values are expressed as plus or minus one point and to be correct I should have specified it this way. In this case I am confident the hardness is between 63 and 64. At this high hardness a thin blade like this would not be suitable for chopping or twisting out of the cut. Joe wanted this knife to be bare bones, no upgrades or special treatment. Therefore the Micarta handle, surface ground finish on the flats, belt finish on the blade and no thong hole liner. I guess you could say this is field grade. I used a similar blade on an antelope hunt a couple of years ago and field dressed, skinned and quartered 4 antelope and just had to back strop a couple of times to keep the edge biting good. Some would not have touched the edge at all and it would have been fine but just depends on how fussy you are about sharp. Rope cutting is a pretty good approximation of the abrasive effect of animal hair and hide so Jims test does give some correlation on what to expect with this steel in the field. CPM S110V is great steel but is still in short supply and is very expensive. I think there is more coming and hopefully it will be available and see more use in the future. It has equal or better performance than CPM S125V and is in the same general category as CPM 10V (K294), CPM 90V. The non stainless (10V and K294) can be pushed to a higher hardness with better edge holding and toughness, but take some care due to the potential for corrosion around salt water and wet environments. I am still working up the best heat treats for the Boher M390 and Uddeholm ELMAX. They dont have the high carbide percentage as CPM S110V and the others but have very fine structure that can offset some of the difference and make for a great all around stainless blade. Thanks to Jim for the extensive test. I know how much work is involved and the time, effort and expense of the rope is considerable. Phil
Found it - Jan 2006 post:
Actually it is on a knife from S110V that you have or had.
I'm worried about getting an s125v from just anybody. Phil says it matters how many times you temper the steel and judging from his K390 I got he really knows his stuff. I want someone that I can rely on to make it as hard but as fine grained as they can because I know I have a knife that is as close to the best as they come with Bow River but I still wonder what a 125 done perfect could do as well.
