Ankerson
Knife and Computer Geek
Cool, ok last question. Do u think I should put 0551 to 30 degrees or 40?
ELMAX can handle either great so it will depend on how well you want it to slice.
Ankerson, the CTS-BD1 and 5160 results are a bit strange..
How would you explain the poor performance of BD1? The 5160 with less carbide forming elements and a very low 55 HRc is in your higher group. I would expect the BD1 being there and 5160 being the lowest of all.
Or am I reading your results incorrectly?
Also, Im sure Im not the only who would be very interested in CPM-3V![]()
Can you tell the manufacturer/model of the 5160 knife?
No worries then. Based on the element composition and the result I'd expect the CTS-BD1 with proper heattreat at the same level with AUS8 and VG-10. This result seems as if the HRc is below 59 which is low assuming your knife was from Spyderco. I can't say I agree about the budget steel, I couldn't find anything to support that.
:thumbup:
Not really...
52100 is high carbon, I think it's 1%.As time goes on, I'm enjoying the few knives I have that are not stainless but "high" carbon. Is SR-101 (52100) a high carbon steel? I like the way it takes a forced patina.
At the moment, I'm considering getting a damascus blade made of 1095 hardened to 58-60 HRC. Would you expect that to be a decent performer in terms of holding an edge? Where might that kind of blade tend to lie in your rankings?
Was just wondering if that h1 was a fresh blade or an old one . As I have heard of it work hardening over time and sharpening
Added 13C26N (Kershaw)
I strongly suspect that work hardening is only noticeable after significant metal removal, and specifically pertains to grinding with power tools.Would like to see u put that h1 to work hard for a couple months. Then comeback and test it again and see if there is any truth to this work hardening thing.
