Looking forward to itAll of them already are on the list except for 420HC.
It was always in the same catagory with those steels in Cat 2.
I'd be interested to see how Fallkniven's 3G powder steel performs. Likewise the rumoured laminated Cobalt powder steel they'll be using this year.
Looking forward to it.
It should be very similar to Kershaws SG2 which is in Cat 7. The Cobalt powder steel is available through Spydercos Mule team and last I saw they still had some at the Spyderco Factory outlet. I haven't done any comparison testing personally but I do like the Cobalt Special ( as Spyderco calls it in the mule team). Easy to sharpen and cuts well.
Joe
First, thanks for all the hard work. I really like the information.
Could I make a request on some additional information on your test ranking page? Here is what I would like to see if possible.
1. List on each steel tested, the knife or knives used for testing the steels (model/manufacturer/maker)
2. List on each category, the range of cuts (upper/lower number of cuts) that the category represents for the steels
This is qualitative information that I think is relavent and also helps to differentiate the categories quantitatively.
Jeff
I'm seriously thinking of getting a Mantis in "440V" if you're willing to put it through it's paces, to see how it turns out. I know a few of us are curious. Maybe pass it off a few times to other testers as well. What do you think?
Jim, any plans to test the newly released CF Military M390 or would it be a redundant effort you think?
That would be awesome! Very curious as find out where it stands against the likes of S90V and 20CP.I plan to if things work out.![]()
I'm also looking forward to some of those steels, such as 440(diff.varieties), 420HC and the chinese commonly used 8cr13Mov
Jim, generally speaking, what would be a good grit to finish with on M390. The knife in question is the M390 Military. Would you finish at, say, 600 or 1000 grit EP or go on to the tapes for a finer polish? Does M390 retain an aggressive cutting edge at higher grit?
I would go with 600 Grit.
Try both 600 and 1000 and see what you like.![]()
