Want to test a Scrap Yard Scrap MAX? I want to see how the busse HT Elmax stacks up to customs.
Jim,
Sent you PM
Spydusse,
I believe it is 60-62. I think thats about the sweet spot for Elmax.
Lol how did i miss that![]()
I saw something that said S35VN was Vanax 35. Is this true I thought they were different?
*cough*
Any chance we could get Buck's 420HC on that list?![]()
Thank you for your post.
Very consistent work, much better than I do
I like the idea of putting them in various levels based on bigger differences as opposed to more absolute rankings based on minor differences.
There is however the perplexing problem of edge retention with various types of edges.
As I'm sure you already know different steels perform differently at different angles. Many of the High carbide content steels are not meant to be sharpened at 15 degrees per side nor are they meant to hold a fine polished edge but will hold an edge at higher angles with a cruder, less "aggressive" edge for a LONG time, while other steels are meant to hold a very fine edge at a lower angle much better.
They are very different steels designed for very different types of jobs. (personally I'm a fan of the finer edge as opposed to the carbide heavy type, although I have to admit the carbide heavy ones do have their uses)
Grouping the different steels the way that you did does pose a possible solution to the problem and I can't help but wonder (and ask) if in fact you plan on adding new catagories for different types of edges?
No, I don't plan on adding more groups with different angles and edge finishes as it's a given that all the steels will cut longer with coarse and thinner edges as well as thinner grinds.
Jim, this doesn't seem to make sense - especially given the debacle of the CRK S35VN testing by CTS and yourself. In that case it would seem to go against what I underlined.
If you have a 10 or 15 degree per side edge angle (20* or 30* inclusive), I'd suspect that the blades would not only get raggedy but folding and denting.
Can You explain the above quote any better?
Another steel E.G. I have a new Endura 4 ZDP-189. I was advised not to run it thin or it would break up. I was advised that the large carbides in the ZDP required a more stout edge (like 40* and not polished) to work best. I don't consider that "cutting longer" or better.
So far this knife has only required stropping but one day I'll have to re-profile and I have no idea what the optimum inclusive setting whould be.
