I only use the Polished edge for these rankings alone.
The other testing is done with a semi polished edge and depending on the knives it could be 10 DPS edge angle.
I do comparisons of coarse edges directly in testing and or when I review a knife.
No, I don't plan on adding more groups with different angles and edge finishes as it's a given that all the steels will cut longer with coarse and thinner edges as well as thinner grinds.
That wasn't the purpose of this being done in the 1st place.
To get them all on an even plane, different angles, grinds etc it would cost one heck of a lot more money that I would ever put into it on a personal level and well above what I have already put out, much more than twice what I already have spent.
I am not rich so that won't happen, I just don't have the extra 15K or 20K to spend for new blades, have them all HRC tested, have them all reground and then test them all again.
The variables have been cut down to the min of what I can do by hand as described in the 1st post of the thread.
Yeah, the only info I can find is from zknives and isn't very positive.In fact, I'm hoping that one day you will be able to test AN-58 steel made by Migeul Neito (Miguel Neito also makes kives for Puma IP, which BTW, is where I got the Model knife I have made from AN-58, the Compania Ameranth to be specific)
There realy are not alot of reveiws for this steel, your testing it could realy help especaily since you do it well
Thank you for sharring it with us![]()
http://www.bladeforums.com/forums/showthread.php/839795-ZDP-189-edge-chipping-testHey Joe,
I paid a premium of $40 on an Endura 4 to get ZDP 189 and have read since then and heard in YouTube that it's not a very good steel. I researched that it shouldn't and can't (not sure which) be brought to a polished bevel of 30* or it will break and sustain damage unless just jutting string, paper and such.
Any wobble in the cut can break pieces of it off the apex. Also that it should be run at 40* and then it's stronger but still remains a brittle edge and as such should be a dedicated slicer only.
Was I mis-informed? My reading makes me wish I would have saved the money and got VG-10 which is great stuff.
Hey Joe,
I don't polish my ZDP ( even though it does that very, very well) but stop at DMT black or Blue. I like the bite of the carbides.
You are misinformed. Did you ever observe such edge damage yourself? I would say that there would be a problem if you run it into metal or concrete, but most steels will have a problem with that.Hey Joe,
Wow!! There goes my idea about maintaining it on a strop!
If you're after a razor edge, I believe 13C26 will hold an edge like most carbon steels. Elmax and M390 also seem to be good for it despite the high carbide volume, though it may be more difficult getting them that sharp in the first place depending on what you have to sharpen with. I'm thinking Elmax might be right for you, maybe a ZT 0560/1? A Kershaw Speedform II would be a good entry for that steel at about $71 on eBay. Small knife, but beats sinking $250+ into one before you're sure.The last I worked with any of the Super steels was the 90's, you are spot on about that one Joe.
Back then they were really crude steels only good at thicker and course edges.
They held a usable edge for a long long time but lacked the ability to hold a fine fine edge very well, so I gave up on the high carbide super steel type blades.
Besides that I have a strong preference against Spydrco's blade and handle designs. They are clever designs, I'll give them that, and the designs are not bad by any means. I just personally really hate it but someone else might love it. Nothing wrong with that, just different strokes I guess.
Unfortunately Spyderco also has the best manufacturing going as far as these new steel types, which is a HUGE factor.
SO! I stuck with allot of German and US made steels. The "old guard" if you will.
As far as AN 58 steel being a wounder steel I NEVER said that.
I have done some of my own testing, and beyond it sharpening like a good hard 440C (maybe alittle better), and hanging onto that TP slicing and hairsplitting edge well enough so far (beating 420HC by a wide enough margin, jury is still out on comparing it to Boker's 440 steels but it seems to be a somewhat better so far)
What I have said however, is that this steel deserves a second look and should be not confused with cheap or recycled steel, or with 420. That this steel is better than that at least.
Beyond that I have said nothing. (well, I found zknives analysis amusing I confess)
I DO know that Neito was dissatisfied with 440c, (that's never been a secret) and had the new steel developed to keep pace with some of the new steels coming to market.
I also know that the composition in AN 58 is on purpose, complete with quality control measures to ensure consistency. What production methods or technology they use I have no idea. Neito is pretty tight liped about allot of the specifics about the steel.
How it compares with some of the newer steels is what I'm anxious to see actually.
Maybe it will only do fair, IDK.
It may be awhile before I drop another one or two hundred on a knife though.
Nonetheless, maybe you can offer me some advice for when I am ready to buy my next knife Joe......
What I look for is keeping the extremely sharp edge longer as opposed to keeping a moderately sharp edge longer, at thinner sharpening angles, say 12 to 17 degrees both sides approx. I use either a strop or smooth sharpening steel to finish depending on what seems to work better for that particular steel (and that one can be a matter of opinion, I learned from both an old barber AND an old butcher) I tend to favor strength and toughness equally with hardness.
Out of the current reigning Champions of edge retension, which steel is the best for that type of edge?
David
PS, anyone try Bokers new Conduir 30 steel yet? Boker is claiming it will hold an edge longer than anything we have seen.
Actually I consider to Lionspy to be ugly even among Spyderco knivesMoi? not able to sharpen high carbide?
Na, I can sharpen any steel you throw at me (well, don't literally THROW it at me)
I prob will get the cheapest knife with one of those steels though and see what they do before buying a model I really want, at some point anyway. The problem with going with a cheaper company is that when it comes to the thin fine edges, care in the manufacturing is just as if not more important than the type of steel. Hence, a cheaper version of the steel won't always give me a true picture of how the better version of the steel will perform.
The Spyderco Lionspy has a blade shape I sorta like, but it's a thicker blade and like all spyderco knives I have seen... it's still UGLY, at least in my opinion. And like you said before sinking 250 bucks it would be good to be sure about it's performance with thinner and finner edges. Sinking 100 bucks and sinking 450 bucks on a hunch are 2 different things.
TY for the advice! I'll post what I find.
I will tell you though, when it comes to hard to sharpen some (not all, but some) of the turn of the century era diamond dust steel blades are the toughest I have seen. Much tougher than any modern High carbide I have sharpened. Although I admit I have not sharpened every kind out there. They (diamond dust steels) require specail stones (which I happen to have), and may God help you if the knife was not cared for in the last 50 years and before that used for gardening like the hunting knife I bought was. It took FOREVER to get that thing straigtened out so it would hold an egde. I still need to work on it's bevel more and give it a proper polish. Not quite done restoring it yet.
It does however, retain it's edge...
Maybe try one of Benchmade's M390 knives?
Actually I consider to Lionspy to be ugly even among Spyderco knives.
I can't say that there's any "thin" knife in Elmax steel. The Speedform II isn't particularly thin by my standards, and the ZT 0560 definitely won't be thin. Maybe try one of Benchmade's M390 knives? I believe a dealer exclusive 710 goes for about $150.
This would be the first I ever heard of a diamond dust steel blade. I did think it was a bit odd that the idea of mixing carbides into the steel matrix didn't lead to mixing diamond particles in the steel matrix as well, but I just assumed there was a problem with the process given that the most I find with a google search would be butcher steels with diamonds coating the outer layer. If it does exist however it would make S125V look like a walk in the park to sharpen. Who makes that kind of knife?
