Thanks for the additions, I've been following this thread closely even before I joined. CPM 3V looks very impressive especially for the toughness you get. Any idea on the hardness it is run at?
Thanks for the time and effort to test my knives. I have wondered where 3V would fall and actually expected it to be in cat. 5.
I will get the knives tested when I get them back so you can add hardness values.
Thanks again
3V really seemed to perform with some of the big boys of steel. Add the fantastic toughness and it might be one of the very best all-around steels. Very few compromises with excellent edge retention and relatively decent corrosion resistance.
I really love my 3V knives and it's good to see more production companies using it and putting it in the hands of the masses.
I'd like to see the knives you supplied for the testing Chris. I'm really enjoying the S90V one you made me.
Iam shocked that Dozier is so far down on the list ..........I thought he would of done better than that , being that he heattreats his own etc.
That looks about right, when I've compared CPM D2 to D2, the CPM would do about 10% better on rope. You can't take the edge on D2 down much thinner or it will chip out badly. Thin primary grind is fine, but not the edge.
Could someone please tell me what page the results are on? I'd love to see them but don't feel like sifting through 50 pages to do so. Thanks.
Roger that. Dozier has his blades profiled perfectly for D2, thin primary and thicker edge. I've done some baaaad things to D2 when I took it down to 10 per side. Learned my lesson.Likely the reason why it also had a 20 Degrees per side edge on it before I reprofiled it.
I really like the fact that you are adding more and more steels. It's confirming some that I've already loved, and also surprising me with others, both good and bad. But that's ok, knowledge is ALWAYS good, sometimes bad surprises force us to re-evaluate our beliefs and become more critical thinkers.
Blade and edge geometry helped it a lot and since there aren't any testable production knives in 3V available I went ahead and tested a Custom from Big Chris.
Don't expect a production knife in 3V to do as well as one of his or you will be disappointed.
