Wow! You read my exact thoughts on that one! I'd like to know this well.
Also, from what I'd gathered, the spyderco brown medium stone (or a similar finish) will give M390 a nice toothy, aggressive, cutting edge that will last longer then any other edge at any reasonable angle? Am I correct in thinking this? I also know that what I'm cutting will have a big role in edge retention. These two knives (PM2 M390 and HTM Gunhammer in M390) are currently in my edc rotation and will be used to cut anything from packaging tape to tie wraps to thin gauge metal if the need were to arise. Both are currently sporting a 40 degree micro bevel, fwiw.
I also have another question, which I think would have the best chance of getting answered here. Has anyone ever done a hardness test on the two Spyderco Gayle Bradleys? Both the large knife and also the Air as I own both and am really curious. Also as a follow up to that, what would be the best working edge for the M4 in the larger of the two Gayle Bradleys? This knife is only just entering my edc rotation and still sports a factory edge. It will be used for the same purposes as mentioned above.
The Air's blade has been convexed, then acid etched, and finally a 40 degree micro bevel was applied. The Air will be carried only situations where a larger folder cannot be. Such as a wedding that I recently attended so edge performance isn't a huge deal here. I will add though that the edge that's currently on the Air is stupid sharp and I'm rather proud of it.![]()
I hesitate to veer sharply off topic, but here's what I remember about the original Gayle Bradley folder - I know nothing about the Air.
According to Sal Glesser, the original target for the GB folder was ~62 Rc (which probably should be a range, so probably 60-62 Rc). The initial production run was tested by both Spyderco and Mr. Bradley at 64-65 Rc, much higher than intended. To my knowledge, no one has ever tested any of the subsequent production runs of the GB folder. Take that where you will...
