Ranking of Steels in Categories based on Edge Retention cutting 5/8" rope
I for one have loved the recent discussion, I have learned a lot about steel make and how it relates to real world use over the last two pages.
I agree that it's a great topic of discussion.
I just think it would be more valuable for those interested if it was split off into a separate thread.
Those coming here for updates on Jim's "Ranking of Steels in Categories based on Edge Retention cutting 5/8" rope" will not find what they're looking for, while those searching for opinions on metallurgy of knife steels are likely to miss it buried in this epic testing thread.
I just find that threads that wander far from their topic title, no matter how good the discussion, are less valuable to Forum Members in the long run.
Just one Forum Members opinion.
Big Mike
Big Mike
Well said.
My apologies, I keep putting "grain" where I mean "carbide aggregate" :grumpy: No, I don't have any data on matrix "grain" size between these steels, wouldn't expect a profound difference anyway.
If 52100 and O1 have among the finest carbides and 4x less carbides-volume than CPM-M4, I wonder why the Charpy toughness data doesn't show it? It does for A2. :confused:
Also, I read that 52100 and 13C26 (AEB-L) have about the same size carbides: http://www.devinthomas.com/faq.cfm
With 4x less carbide volume and 10x smaller carbides, I could certainly see it being tougher as well as stronger, especially at thin cross-sections (blade edge).
Yes, i would expect finer grain/carbide steels to start at a lower cutting load because "edge-stability" allows a more refined & thin apex diameter, i.e. sharper, and the extra thinness magnifies the pressure against the cutting medium whose coefficient of resistance is the same for all blades, i.e. less user force required to induce the same cutting force. However, as I posted earlier:
I should add to the last sentence "carbide type" as well, since chromium carbides won't wear like harder vanadium carbides at the same volume.
But the summation is that I expect all of Jim's blades to have 0.2 um apex-diameter to begin. In this test, wear-resistance from carbides trumps the superior "edge-stability" of steel with finer carbides, so much so that i wondered how important that edge-stability really is beyond cutting fine (thin), clean, non-abrasive materials. I have heard these high-wear high-carbide steels criticized as "taking a crappy edge and holding it forever" or as specialized for cutting only "clean" materials, but I am not seeing either of those things. Is sisal rope so "clean"? Or carpet or cardboard? With the same edge-refinement, I'd expect high-wear and low-wear steels to perform identically in fine cutting - shaving, surgery, slicing meat & veggies. In heavy-impact cutting (chopping), I could see the advantage of the finer carbides preventing damage from lateral twisting at the edge as well as chipping from impact damage, but CPM-3V does that while still evincing much higher wear than 52100 and O1. And in cutting abrasive materials, well, we know how that goes. So how limited are the uses or is the cutting where the superior "edge-stability" of 52100 or 13C26 shows itself?
I haven't seen where Jim sharpens to that fine a finish for his rope slicing testing. I thought he used the 300-400 grit mold master stones from Congress Tools on the Edgepro for his test edges. I haven't read all this thread, so maybe I missed it. I don't think edge stability has a relation to sharpening to a finer edge. It's just that the steels with higher edge stability also happen to be easier to sharpen. Verhoeven didn't do his experiments on high carbide steels. That waviness he describes might well have been edge crumbling, even at the angles he used. The way Jim sharpens, I wouldn't expect a difference between the different steels in initial sharpness. Were there to be one, it could also skew the results. It can certainly do so in CATRA testing.
I think it's a misconception that edge stability is a replacement for, or somehow opposes, wear resistance. No one argues that high wear steels wear slower than low wear ones. What is in contention is cutting ability, which higher stability steels can have over high carbide/wear ones. The high wear steel edges are not stable at lower angles, thus they have lower cutting ability, not lower edge holding/wear, unless one takes advantage of the edge crumbling on abrasive, but relatively soft, materials. Some people prefer different attributes, and some applications demand them. Also in contention is the ability to hold a high sharpness edge. Since a lot if the initial sharpness loss is due to rolling and deformation of the edge, the higher stability steels have an advantage here, or at least no disadvantage at thinner geometry. IMO, few people sharpen to a low enough angle or demand so much of their knives that they'll notice the advantages a high edge stability steel can offer.
you hit the point man , what you said is that i have exprienced with my carbon steel mora , the thin edge is nice and stable compared to high alloy steels.
Testing protocol is at the top of the first page:
Cutting 5/8" Manila rope on a Scale with wood to cut on. The scale was calibrated for the weight of the wood. Making 3 to 4 slicing cuts from back to tip using the least amount of down force needed to get the starting down force. Once that was established 20 cuts were made then down force was tested again and that continued until 20 LBS was reached.
All the knives started at 14 ~ 15 LBS of down force except for M390 because it cuts so aggressively.
Accuracy is to + or - 10 Cuts and + or - 1 LB of down force or 6%. This was verified doing a blind test of blades of unknown hardness until they were tested after. 2 blades of the same hardness and steel, sharpened the same and same model of knife.
RC hardness is + or - 1 RC on the steels that were tested as the standard of RC testing.
All edges were at 30 degrees inclusive and polished to 6000 grit on the Edge Pro, sharpness was tested by slicing TP clean.
Note that all knives were polished to 6000 grit Edge Pro at 15-dps and tested on TP. While he does not measure apex diameter on SEM as above, SEMs of blades sharpened in similar fashion produced 0.2 um edges. It is reasonable to assume that Jim's edges are of similar thickness at the outset, and all knives should have the same level of sharpness. Note the acquisition of "starting downward force" involves making "3 to 4 slicing cuts from back to tip", i.e. the knives are used to cut the medium to acquire the first measurement... and all measure ~ the same. This tells us that at this geometry, on this cutting medium, there is no detectable difference in edge stability within those first few cuts, i.e. the edges of the high-wear steels did not crumble away or show any less stability than the low-wear steels at such a low thickness with a 15-dps edge angle.
Cutting stops when 20-lbs is reached, at which point all knives should again have the same apex diameter. I'd love to know what that thickness is. I'd also love to know how high up the bevel the dulling damage extends, as that would provide information on the performance of alternative edge angles. The edges of the low-carbide edge-stable blades deteriorate more quickly than the edges of the high-carbide less edge-stable blades. If the low-carbide blades held a sharper (thinner) edge longer than the high-carbide blades (as their supposedly higher stability would suggest), that advantage was lost within the 5-lbs increase in applied cutting force. It would be neat to know where that transition occurred or if it was too early to detect by measuring every 20 cuts.
Now, it could be that that the edges of all knives do NOT have the same apex diameter when 20-lbs is reached, that the edges deteriorated in different ways that advantage the high-carbide steels in this test. For example, the low-carbide blades deteriorated by edge-roll which thickens the apex and thereby reduces cutting ability MUCH faster than edge-chipping. It could also be that the low-carbide edges smoothed down while the high-carbide edges chipped into micro-serrations which, again, feature higher cutting ability. In either case, the high-carbide steels have higher cutting ability, not lower. Would this be any different at, for example, 10-dps where Verhoeven describes apex instability (but to a very shallow depth) in low-carbide steels? Perhaps the instability would reach higher up the blade on a high-carbide steel?
Would this be different carving/chopping wood (non abrasive)? Well, neither of those applications requires a very thin (e.g. 0.2 um) apex diameter, so shallow instability is irrelevant. If the low-carbide steel folds over while the high-carbide steel chips away, unless the chipping is much deeper (i.e. to greater edge thickness), the chipping steel still stays sharper (thinner) longer, but you may never notice if both are "stable" (neither folding nor chipping) at a thickness low enough for the application, e.g. 5 um? If you thin the edge via angle reduction to 10-dps or lower, at what thickness do you lose the strength required for the application? Is it really all that different, performance-wise, between low-carbide and high-carbide steels? If your CPM-M4 blade was NOT compromised by a "burnt" edge, then the difference is truly profound! But I would be surprised.
For cutting very soft non-abrasive materials, e.g. surgery, all that is required is a very fine, thin edge - it doesn't need to be very strong. Both low & high carbide steels can achieve that, but perhaps low-carbide steels will resist rolling noticeably longer than high-carbide steels will resist chipping at the edge of my scalpel or point of my needle? I doubt the advantage of the low-carbide steel.
For cutting very hard or dirty materials, the edge needs to be strong and tough but will still lose its very fine edge quite quickly via denting/rolling or chipping regardless of carbide volume? Again, I doubt the advantage of the low-carbide steel.
I think you are right that few people sharpen their edges to such low angles, but I think the reason is because the cutting advantage offered isn't as high as some purport it to be when weighed against other durability issues. Again, the studies of low-carbide razor blades demanded angles of ~15-dps to maintain durability.
Cutting ability is enhanced NOT by sharpening to a lower apex angle that reduces durability but by thinning the blade behind the narrow edge-bevel, i.e. a thinner primary grind or a back-bevel.
As to the advantages offered by low-carbide steels, I see two which my supersede all others: 1) price to manufacture, 2) ease of both initial grinding and subsequent edge maintenance. If the steel is 10x less and performs as needed for a given application, why pay more if you do not need it? And if the edge blunts/rolls but can be re-aligned or resharpened to the needed level for the application more easily, :thumbup:
I never really use angles.lower than 30 inclusive because I find that that will get my knives sharp enough for my uses. Ay.this bevel angle, I find that high carbide steels hold their edges longer than low carbide ones. I have no need for lower angles since I find my edges suffiently sharp. Additionally, I find lower angles, even if they attain higher sharpness easier, get damaged easier with my use too.
I find that each knife I have, I may use a different angle. I have three Spyderco's that I've really been digging. They have S30V, VG10 and BD1. They all take a wicked edge and stay sharp long enough for my uses. I have experimented with different angles and I've found the perfect one for each steel. I think that probably the best edge retention I've seen is on my old Cold Steel Oyabun with a Carbon V blade. The issue is that I NEVER use that knife other than for camping because it's big and bulky. I think we can all become steel snobs and forget that generations before us thought that 420 was a super steel. My dad has gutted and skinned dozens and dozens of deer, elk, turkey and antelope with his old 420 Buck fixed blade. He loves that knife because it works, not because it's the best steel. If you sharpen a blade to a super thin edge, it's going to dull quickly. On my Manix 2 Lightweight with BD1 steel I am doing 25 degrees per side according to my Lansky sharpener. I go up to my 1000 grit ceramic and achieve hair popping sharpness at that angle. It would probably shave at even a wider angle. I don't need to get even close to razor sharp for cutting taped up boxes, cables ties and other EDC uses, but I make sure that they razor sharp just for my pride I guess. Either way, if I can get a hair shaving edge at a wider angle, I'm going to do it because it's plenty sharp and it will last longer. The other nice thing about these 3 steels, and I'll throw in AUS8 too, is that with 3 or 4 swipes on each side from my 1000 grit stone, they are right back to where they were. It takes 30 seconds to restore the edge. Maybe a full minute for S30V, but still it's super easy to sharpen. Anyway, just my thoughts.
This is a very good point imo. We should first think about how we are going to be using a particular knife before deciding on the best angle for the edge. Are you going to be using the knife for duties that might damage a very thin edge, or will you be only shaving hair? ;)
There are too many variables here to generalize. I have found thin edges to be much more durable for some cutting applications than thick edges. Not for others. A lot depends on the steel, heat treat, usage, etc. My only concern is hijacking Ankerson's thread, so I'll stop there, but be happy to resume it in another thread.
I for one truly hopes Ankerson returns soon and cuts more rope. This discussion is awesome but I would like more test results.
And due to this thread I now have one K390 (Mule), a CPM S110V that was heat treated today (Phil Wilson South Fork) and an OTK being finalized in K390. And I thought I had good knives before reading this thread...
I'm wondering more about K390 versus S90V. From the chart on page one, it looks like these are the top two performers in edge retention, and that K390 has quite a bit more edge retention at the given rockwell hardnesses. I haven't found any other pages directly contrasting the two. I've seen them compared... "K390 is to M390 what S90V is to S60V" or something like that more or less equating them, but I haven't seen them squared off. Any thoughts?
I did a test on 63 hrc S110V and 64 hrc K390 in 2 customs and it was very close with K390 having a slight edge. Ive also done tests on rope with S90V unknown hardness probably 60 hrc and I would estimate at least 50% difference between S90V and K390. The extra few points of hardness in K390 makes a huge difference between the two.
Jim has also conducted tests comparing M390 to S90V directly with some excellent info.
Hope this helps, and big thanks to Jim for this thread and his knowledge on the subject.
http://m.youtube.com/watch?v=NkVZj7vUfMo
http://m.youtube.com/watch?v=PFxNLaYtW7Y
I think I've seen your video already, and I've read a bunch of the stuff of M390 versus S90V; there just wasn't a lot on K390 versus S90V, though I take it from some other things that the question should be about S110V or CMP-10V rather than S90V. I have an M390 Benchmade already, and have a K390 Mule headed my way, and was considering getting an S90V mule, but I think from all I've read so far that I should pass on the S90V, as the K390 is probably superior in edge retention. I think some of the other posts I've read are putting K390, K294, S110V, and CPM-10V all in the same ballpark as having the highest edge retention... There aren't really a lot of knives out there readily available in these supersteels.
I would agree with what you said, however remember that the CPM 10V,K294, most S110V, and most K390 are customs. This makes a pretty big difference since manufacturers have to worry more about liabilty because customers will use these steels without the right intentions many times. I will be posting a rope test with 204P and S90V once I get back in town, which may help you a little more.
Do remember when you are looking at these high wear steels, many arent very rust resistant and have much lower toughness, so they must be used for the right applications.
Ok thats my last post about this, not to be rude but this thread has been hijacked to an extreme. If Jim jumps in, im in but this is essentially his thread and I will respect that. Good luck in your search.
Wow it's been a while since this thread was bumped, let's get this back to the first page at least.
Hope Jim is doing well and healed up fit as a fiddle! Also, Spyderco has a few nice steels planned for their Mule Team project hopefully those can be tested in your tests! Looks like S110V and 4V are confirmed with a few other's that Sal has not yet named.
I spoke to Jim a week or so ago. He is healed, but not back at 100%. He did say he is going to try to continue testing though.
That's good news. By any chance, did he mention starting a new test series/thread, "Ranking of Steels in Categories based on Edge Retention cutting 12# Turkeys"? ;)
Edge stability is not relevant with the sharpening protocol used. Edge finish is not the issue, primary grind is a contributor, but not the largest, sharpening angle is. There is too much matrix building too quickly behind the edge for the large carbides to be upset by cutting force to the point of detriment. The matrix is the matrix, if there is sufficient carbon after carbide formation, then there will be hard martensite in the carbide-rich steel just like the steel with no primary carbide. Martensite wears like martensite wears, so the difference is if there is anything else to help with the abrasive cutting while the martensite wears. If the carbides fall/tear out, then there is still jagged martensite that formed the boss around which the carbide lay. So, still a rough cutting edge, which will still wear, and will then present more carbide.
Still waiting on SEM, it is taking a really long time to get all the results, but the initial results are what drive my comments. Reduce the angle and cutting improves. That is with a carbide-rich stainless that is nowhere near the toughness of 3V. Sharpening on a grinder with a 100 grit belt at 10 degrees per side gave the best edge life results. Not the worst, not sorta similar to a 3 micron abrasive, not marginally better. A massive improvement, despite the measurable truths of carbide size or temper loss from power sharpening. Knife edges are not thin, not even as you approach single digit per side angles. You can still whittle wood or maybe chop lightly. You will genuinely ripple the edge of a shaving razor if you cut mercerized thread. I've done it, it triples the force needed to make a cut after the first attempt, the edge is that damaged and visible under mild magnification. This is not comparable to even light knife use, and this is where edge stability is the most relevant. Add much more meat behind the edge, and carbides pretty much always help. Carbides and more steel don't help to shave your face, but that is what specialization in cutting tools is for.
