Vermonster said:
... do not imply that I am a "Mall Ninja".
If I wanted to say you were a mall ninja I would say so, I would not imply it. Do you really feel I have a difficulty in being direct. I don't think so by the way, most of your posts I have read were mainly on bushcraft, mall ninjas tend to focus on extreme situations, which they actually have little to no experience in nor are ever likely to and are basing their choices almost 100% on propoganda.
In the above I noted "mainly mall ninja", not "only mall ninja", by the term I simply mean individuals who will choose knives based on "coolness" factors, usually popularity based and are hugely influenced by any celeb / name endorsement. They also never consider the counterbalance perspective which any design aspect will have and have little to no experience with knives so almost any decent knife impresses them to no end.
In the recent RSK folder post you tied a small folder to a stick and made a small bill hook. You could do the same with the knife in question. It would be a stronger set up overall and less likely to break with heavy impacts. That is just one example.
Yes, and note that the hollow handle doesn't gain you anything as I did it with a knife which didn't have one.
The concept of the hollow handle knife was designed way before Rambo was ever thought about.
Yeah, bamboo handles are really old, they are probably the earliest of such an example, or maybe some of the bone ones. Rambo was just a tremendous influence on its popularity and really brought out the mall ninjas in force on that design, just the "The Hunted" did with the Tracker.
This of course doesn't mean everyone who buys such a knife is one, just that such promotions tend to attract those covert deanimators, lots of other aspects do the same like black blades, "my knives are used by high speed operators", "this is the official navy seal knife" etc. .
I can see the round handle being a problem with a larger knife used for chopping, but not in a small knife like this.
You have the same issues with ergonomics or security with any knife, the lighter and shorter you use a knife the less of an effect it makes. As you go really light, like opening envelopes you can use even boxy handles with sharp edges without concern.
As an example, I recently did some plastic cutting with a Sebenza, decent ergonomics in general, cutting up small pop bottle was no problem, but when I went to the thicker ones and the force was ~75 lbs, the open backed handle design was hot spotting readily.
Compare a pure round handle to something like this :
http://www.bladeforums.com/forums/showthread.php?t=351109
or
http://www.imageseek.com/lamey/gallery/albums/previous/DCP_2276.sized.jpg
for a less aggressive contour and do a lot of extended cutting, whittling, chopping, carving, thrusting, etc., the difference should stand out readily.
-Cliff
