Lee, how do you see repeatable and controlled testing for such a common knife task as wood whittling, boning a chicken or something like that?Repeat after me...
"Repeatable results come from controlled tests."
That was easy.
And what would you learn that isn't already known?
When the alloy was formulated and engineered it was tested using scientific equipment. They can tell you the grain size, carbide distribution, hardness, yield point, expansion coefficient, density, wear resistance, shock resistance and much much more however, what they can't tell you is how well it will actually perform that's because there simply is no machine or computer that can emulate a human being using it.
I'm pretty sure manufacturers heat treat their steel before testingWhere's the heat treatment in all of this?
Believe it or not, casual ppl break a lot of knives. Accidentally, by misuse, by ignorance and so on. And they too, cringe when that happens, sometimes bleed too...who cringe at broken knives.
So much depends
upon
a exceptional heat
treatment
employed by knowing
souls
knives.
Your absolutely correct heat treatment is important !!!!
All I meant is that one manufacturer's heat treatment might not be another's, even with the same steel. Still, I agree that each manufacturer might/should be able to provide you with information on a lot of descriptive categories, including heat treatment.
But what Ebbtide indicates about a sample of one is true. One knife failed exactly as Noss4 showed. Can you replicate it? Well... if you can match each and everything that he did to the knife. Maybe there's some value in understanding a range of abuse prior to failure??? But you'd have a hard time duplicating that exact measure of abuse shown in a video.
If the videos float your boat, great. Just don't pretend, as some do, that they are the end-all, be-all for every knife, or that they're somehow "scientific" in nature.
Those who feel that pure scientific data acquired through strict protocol is the only thing useful
They're not an end all at least not to me however, they do provide insight.
Those who feel that pure scientific data acquired through strict protocol is the only thing useful will never see anything useful in these tests. And some of them cringe at the thought of scratching a $400 knife.
Vassili likes what nozh4 does, and many others do too.
Nozh4.
LOLSteven, It's Noss4, not Nozh4. Vassili is Nozh2002.
Regards,
3G
IF he made the "tests" MORE "scientific"...even working with the manufacturers in the cutlery industry to compromise on what he "wanted" to do, vs what the manufacturers felt were valuable tests...there might be less antagonism...and a lot more general interest amongst the "old timers".
I've never claimed the videos have no value at all. They just don't have that much value for me personally. Mainly because I realize that most manufacturers don't design their knives (or recommend) for folks to wail away on the spines with a two-pound, steel hammer.
