- Apr 10, 2000
Ok, it's pretty much the same idea as with Mythbuster's chopping rig, which you yourself agree isn't the epitome. Anyway, ok, we have the rig and it will provide the data exactly how many chops would it take to go through a cinder block, what force, initial edge, etc.The cinder-block-buster-o-matic consists of a rigid pole/lever upon one end the knife to be tested is attached.
Removing human factor or error, when I am looking for the properties of the steel or handle material or cinder block in general is fine, nothing against that. However, that data is readily available for every steel out there. Toughness and wear resistance charts, whatever else, it's standard and well know science and methodology is there. No need to come up with our own rig for that data.The point of using a machine is to remove human error from the equation.
My problem with this approach is that in everyday life knife is never used in the rig setup, and human factor or error is constantly there, that is how knives are used, with those errors and removing that from the equation won't necessarily give more accurate results.
Honestly, what do you think if you were to chop through the wooden block and we'd record angle, velocity and force of each swing or chop, what would it look like on the chart, closer to Noss results or closer to machine result?
That is based on the assumption that the knife in question is used EQUALLY in all the envs you listed. Unfortunately humans can not use the same knife equally even in the same env.The point is that with appropriately bounded data, one could say that x knife is tougher than y knife regardless of environment (field, shop, or lab).
Let's look at another rig. Which would be a metal cutting machine in any factory. Which holds extremely hard tool steel blade and cuts n feet of metal before needs replacement. That is similar to your test rig right? Should work fine to get an idea of metal's wear resistance at that hardness. If we follow your logic this test is perfect because human error is removed, we have bound data, no variables or deviations, controlled env.
Given that setup you could conclude that the best hardness for XY steel steel is around 67-68 HRC or even grater, I don't know what's the max for the industrial applications.
However, if someone made a knife for you with those parameters, how long do you think it would last in your hands before chipping or breaking?
So, I don't think completely removing errors and deviations from knife testing is giving more accurate results.
Yes and no, in practice not being an expert in particular area is also a reason why your expertise, critics and such won't be always correct and will have less credibility than that of an expert. I don't imply Noss is scientist or an expert. This is about you and your input on the knfie testing subj. Which also means, me not being an expert in this field can be wrong too on test methodology.You don’t have to be an expert in a particular field to recognize flaws in testing methodology, or the near absence of methodology all together.
