- Jun 10, 2003
Slight changes in the cross section of the epee blade certainly can make a big difference.It was much easier to try the blade rather than try to measure cross section. A soft section in the blade will bend in use , then you are constantly straightening it !! My failure analysis was done for the most part on foil blades [pre-electric] and found they were made of dirty steel .The sharp corners also on beats put nicks in the blades .Typical failures were fatigue failures due to these two factors. Maraging steel blades ? They're supposed to work much better .Most maraging steel goes into golf clubs today !!! My thesis was about a maraging steel and I knew much about the use and development of the steels .Those metallurgists would cringe if they knew about the golf clubs !!
