I've found an option to buy Shapton Pro that're fractions of a stone cut-off so that they fit my Fixed Angle Sharpener.
Obviously the cheap stones my kit came with got knives pretty sharp, but not that super-sharp edge most of us buy setups to get.
And I assume it's going to take a better set of stones than the freebies my set included.
What grit Shaptons cut to fit my FAS would yield that kind of sharpness..?
- Would: 320, 1k, 2k, 5k ... be adequate..?
- or do I need 320 -- 12k ..?
How many strops do I need after..?
I'm assuming I wouldn't need Diamond Plates unless I need to re-profile knives, and then, probably only in the lower grits (220 -- 400)
I've also read people rant and rave about a COTICULE ...? What does it do that a set of Shapton Pro can't ..?
After getting to a 5k Shapton Pro ... what strop would be appropriate..?
Do you need more than one micron strop? Or can you use 1 strop with 3 micron emulsion on one side and 1 micron on the other..?
Again ... I want things that produce obvious benefits,
ideally while avoiding 2x the money on items ~10% better...
Suggestions and logic will be immensely appreciated.
Thanks!!
Thanks!!
