Prices have obviously gone up. I paid under $40 for one.
Which item were you referring to ..?
Sorry, the Wicked Edge design.Which item were you referring to ..?
I apologize in advance for this Uber long letterSo ... what do I do!??
- Get diamond stones..? (They seem to remove material v well)
One of the problems with staring at a project for so long is that it is impossible to see it anew. I do try to make it intuitive or at least intelligible. The sheer number of columns is overwhelming but I keep the major standards toward the center so that one can focus on that part and read outward only as necessary. If you have questions about it that are not addressed in the README I am here to answer them. If you have suggestions to improve the chart or the readme please let me know.I know I'd need to put some work into understanding it before I could use it.
I'm guessing you had to choose between intuitiveness to layman (me) & accuracy for experts.
I suggested it to you (unironically) thinking "he might be familiar with enough items on it to read it."
Great! I am glad you like them. I ordered a couple from the seller you referenced as at those prices it's kind of silly of me not to have any experience with them. (Thanks by the way.) This time I went with the most popular options, 1000 and 2000.Anyway, back to this lamens world:
Got the Shapton Pro I ordered and they are very good. INFINITELY different than the crap I'd used previously ...
Way, WAY finer than anything I'd used also. The Shapton Pro in 320 is finer than the finest stone I'd used.
Awesome. Thank you (and yes, I know what you mean. I always think it's best to have beginners or novices re-explain things I've said, or, ask questions to generate responses that are accessible).One of the problems with staring at a project for so long is that it is impossible to see it anew. I do try to make it intuitive or at least intelligible. The sheer number of columns is overwhelming but I keep the major standards toward the center so that one can focus on that part and read outward only as necessary. If you have questions about it that are not addressed in the README I am here to answer them. If you have suggestions to improve the chart or the readme please let me know.
Great. The one thing I would've done differently is ordered blanks in order to mount them on aluminum. Sure, the CF should be strong, but I'm guessing that CF is harder to 'flatten' than aluminum ... as you could use a mill with a fly cutter. Obviously it'd be better if they used a surface grinder!! But they aren't going to put that kind of time and effort into a set of blanks that cost $15 for a set of 6!! (Which I found on a site).Great! I am glad you like them. I ordered a couple from the seller you referenced as at those prices it's kind of silly of me not to have any experience with them. (Thanks by the way.) This time I went with the most popular options, 1000 and 2000.
No way.If the Shapton 320 is finer than any of the junk set it sounds again like the one I trashed. Remember how I said it seemed like they just printed numbers on them at random?
That may be, but to my knowledge that'd be an even harder means for people like me to determine bc while the composite efficacy of a stone isn't stated against a universal reference ... and there's even less info about the grit independent of the bonding, and bonding independent of the grit. ;-)For conventional abrasives (alumina, silicon carbide, etc.) the optimal bond strength depends greatly on the steel being worked and the pressure (force over area) applied.
Cool ... I actually already started to recognize that today, though it'll take a while to develop expertise.In time you learn to work with breakdown instead of fight it, but some prefer to walk on one side of that line, some on the other.
Yup...I already thought about (eventually) buying full size stones if I stick with this hobby.Personally I have mostly moved away from using very coarse stones on a guided system for several reasons.
* Cheaper per unit-mass of abrasive stones cut for guided use
* Far more surface area = less frequent flattening of the stone
* Longer strokes to more safely lean in/add force, working faster
* Full thinning + face work that's impractical on the Edge Pro
* Don't need to tape both faces to avoid scratches from coarse mud on the blade table (Edge Pro problem)
Goooood info. Thanks.T2 fall into the same category as Shapton.
Good good ... I'll grab those.I'd recommend Congress Tools Moldmaster stones, which are similar [to Shapton Pro] and well regarded.
I'd recommend: 80, 120, 150, and 240 in 1 x 1/4 x 6, The entire set will cost ~ the price of one Shapton Pro.
Wait, bonded diamond..? I thought that was why the ones I had 'ripped'..?The "3-layer diamond bars" sound interesting, perhaps lasting longer than other plated types, yet being less expensive than bonded diamond.
Looks like you'll need blanks to mount those yourself, like the Congress stones.
If you know you are going to do a lot of roughing with your system and you know you want diamond (or cBN) a single bonded diamond stone may ultimately be a better investment, having far more than three "layers" in its thickness. You could then clean up after with a MoldMaster or Shapton.
My thoughts exactly. lol. Exactly.If you order a Shapton 8K or 12K perhaps combine shipping with this.
Yup...I'm going to dive into his post and reply there as well. He has a lot of interesting points.The "3-layer" bar sounds not too impressive in his hands so I will pass on buying the 80/63 as I had proposed.
I apologize in advance for this Uber long letter. First I’d like to say, that I’m relatively new to sharpening.
That said, I have used the TSPROF plates and they are alright, for what they are. Yet, they can’t compare at all to my EP diamond Matrix, for example. So far I only own the 1700 (10um) and 4k (5um), but will get more of them.
I also have the 120grit CKTG plate and it’s fine for rough work. The TSPROF plates seem not bad, for what they are. The F150 seems finer then though, even for fepa 150.
I upgraded to some Poltova CBN stones, which I ordered directly from them and they should be on their way now. I ordered their “combined” hybrid CBN stones. The bond is a metal-resin bond. Which is supposed to be less aggressive then the metallic cbn, yet still more aggressive than only resin bond stones. Although, the 20/14um size stone is resin only. So the combined bond stones I ordered are 63/50, 40/28um hybrid and 20/14um resin only. From there I jump to my matrix 1700 and 4k.I mostly use plates in 100grit 150grit and 220grit (although the 220 will get replaced by the 63/50um Poltova). Eventually I will upgrade to where all grits are stones, instead of plates.
I also ordered some CBN and Diamond paste, but still use my gunny juice. Which is the greatest diamond emulsion I ever used! Then again, I haven’t used a whole bunch yet, either.
I also ordered some Kemet diamond emulsion and can’t wait to try it out. I live in the Yukon Territory (far north), but am in a bigger town for medical at the moment, which is why I’m buying a bunch of stuff before I head home again, since it’s a lot more difficult to have stuff shipped to my PO Box up north, especially during winter when, usually, anything freezes in minutes (-40 there at the moment).
Mykhaylo, who seems to be the owner or manager of PDT, was really awesome to deal with, btw. Very professional and helpful and if he didn’t know something, he would check with his specialists at the factory. Super great guy to deal with.
I’m thinking of doing a little review about those stones and my experience with PDT, once they arrive and I used them a few times. It will obviously be through the eyes of a beginner, but I think some people might still find it interesting regardless, especially since those “combined” metal-resin hybrid stones haven’t been used much yet. Although the Hapstone premium Diamond/CBN are a hybrid metal-resin bond as well, I hear.
That said, the reason I ordered from Mykhaylo directly is cause I will be visiting my folks in Germany for 6 weeks soon, so it was a lot easier ordering directly from them.
Anyways, as mentioned above, I haven’t used many different stones, to make a good comparison yet. So please keep that in mind. The diamond I have used are KME Gold Series Diamond, DMT diafold in coarse/Fine, TSPROF plates, CKTG 120 1x6 and a 400/1000 bench stone, Hapstone CBN plates and the diamond Matrix stones. IMHO the diamond matrix are on another whole level than the rest. Since they have a relatively soft bond, they give great feedback. Which even the cbn plates can’t compare to, again imho.
The Hapstone CBN plates had some defects, but Mario from Hapstone was awesome about it and my replacements will be on the way soon. Excellent customer support!
That said, I wouldn’t order the CBN plates again and instead go with either metallic, or possibly the “combined” bond stones. Buy once cry once, I guess.
Holy, I apologize for this long message, which turned into half a letter. I just thought I’d let you know my experience a bit, since I had similar thoughts and questions as you. Especially, since you mentioned some of the stones and plates I used before and thought to let you know the experience I had with them. If you decide to go the diamond matrix stones, I think you’d be very happy with them. Same with pdt, I’d say.
The guy that developed and made them, D Diemaker , is a member here btw. Great guy, too!
Anyways, you probably have blood coming outta your ear by now, after such a long message.
Would anyone like to see the actual products (Shapton Pro) I received..?
I have several knives to reprofile so I went ahead and took your advise to T TrumanHW and bought the mold master in 1/2 inch thickness. I have a good angel cube so it should be a good compliment to the alox edgpro stones and diamond plates I already have. This hobble is starting to get even more expensive.I recommend you get the 80, 120, 150, and 240 in 1 x 1/4 x 6 size. Th smaller particle size than the Shapton 320 but probably is not nearly as smooth in feeling. The 80 grit may be below the point of diminishing returns but it is only $5 so worth the experiment IMO. The entire set will cost about the same as one Shapton.
I don't see the point of careful flattening if they aren't used as tape blanks.Great. The one thing I would've done differently is ordered blanks in order to mount them on aluminum. Sure, the CF should be strong, but I'm guessing that CF is harder to 'flatten' than aluminum ... as you could use a mill with a fly cutter. Obviously it'd be better if they used a surface grinder!! But they aren't going to put that kind of time and effort into a set of blanks that cost $15 for a set of 6!! (Which I found on a site).
No, you did well. 1: A 5mm thick 5000 Shapton will last a really long time. 2: You're going to want adjust for stone thickness every time you change fine stones anyway, if you want to hit the full bevel. 3: It's better for fine stones to be thinner than coarse, rather than the other way around, as if you don't adjust the pivot height you naturally hit the edge and get a micro-bevel, rather than hitting the shoulder.I made a 2nd mistake thinking the 5,000 would be harder, last longer, and thus, I could get away with the 5mm thick instead of ~12mm thick ... as it means I have to adjust the HEIGHT!!! On my FAS!! You'd think the 4mm wouldn't matter ... but of course it does. I'll never make that mistake again.
No way.
- 1,000 is obviously finer than the 320
- 2,000 is almost polishing
- 5,000 absolutely is a polishing stone. Making the edge like a MIRROR.
You'll see!![]()
No, I use those myself. I file the pointed corners so they don't catch as I put them in and out of a storage box.Here's the blanks I was mentioning before ... anything wrong with these..?
(I saw your addendum on these below, don't worry)
- Single Bonded..? Are more expensive..? Vs ...what? What are the qualitative categories for diamond..?
- Should I have a preference between Diamond or cBN..?
(or is it based on the actual qualitative-choices that exist from mfrs..?)
BTW ... is cBN like a diamond stone..? in that it doesn't wear..? Or is it more like the aluminum oxide stones which wear ... but in which the particles are diamond-esque in hardness..?
