Cliff Stamp said:
M2 is far tougher than S30V at a similar hardness and has finer carbides.
-Cliff
I never found a direct comparision data. Just Damasteel is promoting their PM steel to be stronger in bending resistance (not impact toughness) even than high speed steel.
The PM process should produce much finer carbides than conventionell production. Even finer than carbides of an secondary level, like in M2.
So, how do you know that M2 is tougher? As far as i know M2 takes more until bending but snaps as any other high alloyed steel. Considering impacts i doubt M2 to be somehow tough.
I imagine, that the total carbide volume in M2 is lower than in S30V. This may lead to less chipping. Again, my chips are more to feel than to see. Further i think, that the higher atainable hardness for an average edge of M2 keeps the carbides in place better than S30V, which is run slightly lower or for example D2, which seems to hold a better edge when harder but looses bending ability.
Or, do you know better?
My experiences didn´t change with repeated sharpenings, the chips came back.
Maybe i should be more precise: I checked the edge after cardboard cutting with no chips and had the case of a chip without really cutting with the knife, a few days after sharpening.
Sometimes there is a kind of rough edge at the belly, which only disapears if grinded.
To me everything points towards the internal structure of S30V. Maybe the carbides are not as fine as promoted.
