It does make me wonder if they handle the mirrored 189 ZDP blade differently than the DLC version.
From what I've read it's the same thing, but after they polish the raw YXR7, they add the DLC coating. Rockstead recommends resharpening in a manner similar to my own; 2000 grit wet/dry sandpaper. I wouldn't be surprised if they use the same method.
Even though the bevel is ground down to the edge, when I sharpen on sandpaper only about 15-20% of the bevel lays flush against the surface. Reason being, is because you are tangent to what is essentially a spherical surface.
Basically what I'm saying, is if they use said method to sharpen, they wouldn't be "grinding" the entire bevel anyways; so it wouldn't get entirely polished. We will see
