Larrin
- Jan 17, 2004
So what you're saying is that even complaining has a flavor of the month club. Some linerlocks are good and some are not. Some steel is heat treated well and some is not. What do you predict will be the next flavor of the month for complaints? ZDP-189?Was there a large reduction in reported problems with liner locks awhile after Mike, and later Steve and Joe's comments were origionally posted/discussed and supported by other users - yes. There was an initial large flood as many people posted support but after awhile this died down and now there is almost no discussion or commentary in that regard. Did the locks actually get better - no. Discriminating users simply looked elsewhere or relegated liner locks to less demanding use. However did this cause a large drop in the sales of liner locks - no. Does this mean that Joe, Steve, Mike and others didn't point out a significant and inherent problem - no.
Even if the defect rate on S30V was insanely high like 25% (it likely isn't even close to this), if you factored in the effect of the percentage of discriminating users, then the percentage who wrote off the steel, then the reduced amount they buy (users don't tend to buy the same volumes as collectors, and serious users even less so) it would be obvious that the total volume of sales would not be adversely effected. You really can't use popularity to argue performance in either direction, if you did you would have to accept that 420 stainless is the best cutlery steel.
Plus would you really expect manufacturers to actually make public statements about the popularity of their designs/steels being reduced anyway. Unless you have some kind of independent ability to audit their records you are essentially letting salesmens give you information on the popularity of their product.
-Cliff
