- Oct 3, 1998
Just got in a couple of the new Darrel Ralph collaboration pieces made by Taylor Cutlery under the Smith & Wesson banner.
One of the folders. This one also involved Mike Lamprey. Blade length is 3.6" and is of 1/8" stock of 440C. Double integral guards also are opening devices either by using the flipper method or usinig your thumb to push the top guard. Handle is of magnesium, this is the only production folder I am aware of that uses this material. Handle length is 4.5". Double stainless liners underneath. Liner lock®. Pocket clip mounted high to carry knife tip down.
Fixed blade fighter/camp knife. Those of you who know Darrel's work will clearly see that this knife has his signature all over it. 7" recurve clip point blade is of .220" 440C. Handle is full tang construction with textured Zytel scales that are screwed on. Notched thumb rest. Kydex look-alike sheath with molded belt loop carries this knife in either horizontal or vertical positions.
Believe it or not, these knives are very well made. Lockup on the folder is spot-on. No play in any direction. Fit and finish of both are very good. The fixed blade IMO is particularly impressive. Only complaint about the fixed blade is the Kydex style sheath. It's not really Kydex, its some sort of thin thermoplastic. Got a flimsy feel to it and you can flex it easily with your hands. Time will tell if it will hold up. Riveted halves.
That's about it. Those of you going to Blade Show, owe it to yourselves to check these two knives out. They are of CRKT level of quality. At this point in time I have no idea on SRP, but will post here when I find out.
Proud member: AKTI, NCCKG, NCKK, and SCAK
NC Knife Knuts @ Table 18-B at the Blade Show
Living life on the edge
