yultuz, can you post a link to the info you found on the ZDP?
Why are they no longer made?
Does S110V have better edge retention than VG-10 or BG-42?
Absolutely. It has better edge retention than ZDP and S90V also. It's an amazing steel, and is capable of being run at higher RC's than S90 even. Joe
Either one of these knives will give you years of excellent service
Unless you plan on scuba diving with it, I respectfully disagree. My ZDP Leek, manufactured in July 2006, doesn't have a spot of rust on it anywhere.
yultuz, I use my ZDP Shallot in the kitchen frequently. I don't hold it under running water, unless I'm prepared to take it apart later and clean and re-lube it properly. I've cut pickles (no change in color) celery, eggs, chicken, fish, meat, apples, pineapples, oranges, grapefruit, garlic, lemons, limes, potatoes and just about anything you can think of that you would use in food prep.
When I'm finished, I wipe the blade clean and put a drop of mineral oil on a paper towel and wipe the blade. I do this with all my kitchen knives, including 1095, 154CM, 3V, D-2 and SG2. With just a few seconds of preventative maintenance, you'll have no rust.
And if you want to use it for food prep, stick with mineral oil for the pivot, too. Non-toxic!
