Originally posted by Scott Dog
S30V seems to be the new darling steel, it's supposed to be "better" than BG-42 (why I couldn't tell you to save my life).
Because, roughly in order of significance:
1.  it is tougher at a given hardness than other high alloy stainless steels
2.  it contains more Vanadium for wear resistance via carbides than BG-42 (4% vs. 1.2%)
3.  It is a CPM steel so should be as good or better grain structure-wise (very fine and uniform distrib of Vanadium and Moly carbides... contributes to toughness, and arguably to ease of sharpening and ability to take a refined edge).
4.  And it is supposed to be more corrosion resistant that the 14-4 Cr/Mo steels (ATS34, 154CM, BG-42).  (more free chrome left after heat treat).
It isn't a "darling" in any negative or hyped sense (that is not to say there won't be hype out there).  It is a solidly, genuinely incremental but notable improvement over all other "stainless" class steels in
overall balance of properties.  It isn't as tough as 3V or A2 or especially the simpler carbon steels (O1, 1084, etc).  It isn't as wear resistant as S90V or 10V.  It probably isn't as corrosion resistant as 440C or 420HC.  S30V's claim is overall balance for a stainless.
It was sharp but not Bob Dozier sharp. I sent it back to Idaho for a silver double thumblug and a "tune and sharpen". It came back with a Dozier edge.
Actually, Dozier's knives come quite sharp, but I believe are just sharpened on a belt grinder.  And while they shave, they are quite aggressively toothy, not polished.  And they are a flat final edge bevel (hollow ground blade of course).  Which is just fine for a working knife designed as they are to be.
Reeve's knives usually come even sharper but more polished and not toothy... they are of course hollow ground, but the final edge is quite polished and slightly convex, done on a hard felt wheel.  I view Reeve's edges as being a fair amount more refined than what Dozier chooses to put out (not criticizing... Bob puts out his work at what is admittedly and by choice a very nice price point).
To my arm hair, Reeve and RJ Martin and Scott Cook's knives come about as sharp anyone from the custom side (Yeah, Reeve is semi-custom or high end production, whatever).  I only have one Mayo and bought it used, but it had a polished and broad and slightly convex edge on it also.  The Busse Custom shop sure put a great sweeping convex edge on my flat-ground Active Duty.
Very sharp, and polished.
Spyderco and Microtech do a nice job out of box also. Again a flat final edge bevel like Dozier.
