I just re-read that thread.  Whew.  You picked a good one.  Lots of good information and insights, and a certain amount of ground clutter, misinformation, and backwards logic to wade through also.  The BF reader is best served if they have a skeptical eye and good BS filters in picking sources to listen to, digest, and incorporate.
Harrydog, I think you should buy a new S30V sebbie, and buy a used BG-42 sebbie, and do some testing side-by-side on the hardness issue and edge roll issue, and tell us what you think.
  Great excuse to buy two new folders.
And, I'm not trying to stir the pot with what I'm posting here today.  Just some perspective, from one guy, who likes his 4 Sebbies fine.
Rc58-59 to subject to edge roll?  You might be able to tell a 58-59 knife apart from a 60-61 knife after some side-by-side testing in looking for edge roll.  Maybe in daily use after a while.  But if the 58-59 knife is tougher and more abrasion resistant, it may have a broader range of performance vs. varying cutting chores overall.
The original source of confusion and questions came when, after offering BG-42 (and ATS-34 I believe) at Rc60 for years in the Sebbie, Reeve dropped S30V to Rc58-59 target (early incorrect info said Rc57-58, others mutated to Rc56-58, etc).  Why the questions?  Reeve helped develop S30V with Crucible, and Crucible's stated design goal was to be "A2 tough and 3V in edge retention while being stainless... or as Crucible reps stated in conversations at the 2000 Guild Show, "Stainless 3V" was the goal, a tall one but illustrative, for S30V.  I.e., the toughest true "stainless" on the market while having hardenability and carbides to also be good vs. abrasion resistance.
So S30V is tougher than BG-42, and yet Reeve drops hardness target?  That is where the questions came from.  Lots of things can be inferrred from that, and Reeve didn't really cut through the fog in his responses... he came off as a bit defensive and not completely  direct in his commentary.  One easy inference is that, well, if S30V is tougher at a given hardness than BG-42, then BG-42 must have been a bit brittle, based on experience and customer response, at Rc60.  Chris never allowed this was an inference nor would he address this directly.
What would help somebody like me is a set of toughness vs. hardness curves for both steels, given a good heat treat.  Graphs are worth many thousands of words.
Also, know that Rc is not completely linear.  The machine uses a conical shaped point they push into the steel under known load and they measure linear travel, but that travel is incurred by a "cone", so the displaced volume of indented/pushed-aside material increases with travel.
An example to illustrate, that does carry a few simplifying assumptions:
Wayne Goddard has stated that, in his testing, a blade at Rc52 will barely hold an edge, as indicated by one or two good cuts on rope.  Below that and you have a pry bar with a momentarily sharp edge.
			sidebar
anyone who has owned a regular 420 steel bladed knife (not talking about 420HC now) knows how poorly a soft blade holds an edge, and how stubborn the wire edge burr can be to get rid of, calling into limitation the accuracy of the simple statement that "softer is easier to sharpen".  Softer is easier to sharpen without a good sharpening stone (e.g. a rock in the boonies), but softer often makes the burr harder to remove, makes it harder to get a good, clean shaving edge without burr.  A burr will shave, by the way. Just a weak edge.
Assume for a moment that a practical maximum for today's cutlery steels is in the Rc61 to 62 range (even the tough steels are getting practically at least somewhat brittle past this range, but even here, a restricted (slicing) scope of work for a hard blade, or perhaps special alloys, could be the exceptions to this general rule).
So from "barely a blade" to "practical maximum", you may have ~11 Rockwell C points to work with.
Ignoring non-linearity of the Rockwell test for a moment, this implies that a 2 point change in Rockwell can have a 2/11 percent (18%) change in resistance to edge rolling and impaction (which are for most people not cutting abrasive materials like cardboard and carpet all day, the primary dulling mechanisms).  Yeah, this example is laden with simplifying assumptions.
So don't miss the big picture "point":  a 1 or 2 point hardness change isn't a 1/60 or 2/60 (1.67% and 3.3%) change in performance. It's a 1/11 or 2/11 (9% to 18%) change in resistance to impaction and edge rolling.
Toughness is typically far more non-linear w/ hardness than is resistance to impaction/edge rolling.
Using the search engine, you can learn that one of Reeve's primary drivers in selecting hardness is an ease of sharpening, which he must believe is of importance in servicing his client base.  And that's fine.  Also, his A2 at Rc55-57... depending on heat treat and edge profile, A2 can be as tough at 59-60 as it is at 55-57 range, it has a weird double hump in toughness curve (I will say I don't know if the curve I saw was transverse or longitudinal charpy impact toughness... I'd have to dig.  And some claim it doesn't translate too well to knives since charpy is run on test blocks, in the interest of full disclosure).  So the 55-57 is purposely biased for "ease of field sharpening".  Also know that good quality, small, cost effective diamond sharpeners are available for pouch carry in a good field sheath.
You may agree that ease of sharpening should be high on the list of performance attributes to balance, or you may not.  Just keep in mind that, in general terms (ignoring grain size for a moment), if it's easier to sharpen it is also easier to roll or otherwise dull.  Think about it.  Decide for yourself.
And for the record, I own 4 Sebbies.  Reeve is a maker who's approach towards tolerances, precision, and QC, I respect greatly.  And that convex final sharpened bevel is a gem.
Ok, with all that microanalyzing done:  While my Sebbies are (1) ATS-34 and (3) BG-42, I'm sure the S30V's at Rc58-59 work fine.  You should buy multiple of them and test the Sebbie in S30V and BG-42, side-by-side, in carefully controlled cutting tests, and tell us what you think.
