Has anyone produced facts about Paul Bos?
Of course try to make it personal Jerry, what I said clearly has it been PROVEN that he is actually so much better than the competiton. Does Buck knives have a higher QC than Spyderco? Does Paul Bos have a higher QC than R. J. Martin. How about presenting some FACTS?
If you want perfect edge stability where no carbides will be dislodged under any circumstances, simply reduce the carbon to virtually zero. Carbides are what gives the steel wear resistance and strength - fundamental requirements of a knife edge. Those are the attributes which are lacking in 440A and 440hc.
Wear resistance is highly correlated to hardness (though yes carbides as well) and carbides do not give a steel strength. This shows a COMPLETE lack of understanding of even basic metallurgy. Here is an example which shows what you just stated is UTTER NONSENSE. Take an ANNEALED blade of S90V, this is chock full of carbides. Now perform any number of MEASURED MATERIALS TESTS on strength. How will it perform? Does anyone really dispute it will be very weak? Now try the nail cutting, how come it will fail badly?
Virtually all high alloy steels were developed for things other than knives. Why did industry feel the need for high carbon, high alloy steels?
In controlled cutting where impacts are low then such steels are frequently used, when impacts are frequent they are not. This is why F2 and A8 class steels both exist for cutting tools. It is also why steels like F2 will be used even though steels like D2 have much greater wear resistance. They simply can not hold fine cutting edges the same, the edge stability is too low.
Note as well you are still ignoring FACTS, steels like 52100 when heat treated properly do not actually put all that carbon into solution because it will generate plate martensite which is so brittle it is prone to cracking even when forming. 52100 has the SAME carbon in solution as the steel 12C27M you denegrated. If you are comparing the alloys then you have to look at how they actual are involved in the crystal transforms, not simply on the raw numbers. Thus if the low carbon value of 12C27M makes it inferior then 52100 is also inferior for the same reason.
Actual FACTS from Howard Clark :
[refer to 52100]
"If too much of the available 1%C is dissolved into the austenite solution, you will get "plate" martensite, which is more brittle, always, irrespective of actual tempered hardness as measured on the rockwell scale. Austenitizing temperature for 52100 should normally be held to 1550F or less. At 1550F, there will be .55-.6% of the available carbon dissolved into the austenite, with the remainder present as retained carbides in the martensite that is formed in the quench. This is good. Over-heat the blade to 1650-1700F (real easy to do by the "eyeball" method, and you may put as much as .65-.8% of the carbon into solution. This is bad."
Note his point about plate/lathe is UNIVERSAL, it is not simply an issue with 52100.
Carbide fraction & volume tells you more about strength than a Rockwell test?
As you proposed, no. The hardness test is highly correlated to tensile strength, the example of annealed steel shows the complete fallacy of the carbides = strength arguement. Spheroid annealing produces large carbide aggregates and the purpose is to make the steel DUCTILE, it is very weak as with all annealed steels. Note when you draw the temper of a steel by overheating it, you are actually coarsening the carbides and removing the alloy from the matrix itself. Now does this make the steel stronger or softer? As a known example, Talonite has a high carbide volume, but the hardness is so low the edge will deform very readily.
then why is buck the only company that people refer to when they want a reliable blade in 420 steel?
Has anyone performed blind tests to show that Buck's 420HC is actually superior to other similar priced class steels? How are Spyderco's low carbide steels such as used in the Byrd line or the AUS-6 line compared to Buck's 420HC?
here's a thread where Ed Schempp talks about using 52100 in a large chopper/competition knife. He mentions the finer grain sixze, toughness, ease of sharpening, and reduced likelihood of chipping in comparison to CPM steels.
One would hope so, otherwise a lot of ASM books on metallurgy have to be recalled. However on an amusing note there is a P/M version of 12C27/M.
-Cliff
