- Oct 28, 2017
Yeah. That looks very obtuse.Looks legit, but look at that bevel.
We now know your sharpener is no good for sure.
Images of Said Knife, my Delica VG-10
Im not sure how to make this link into active pictures on here
Images are here
https://imgur.com/a/dFMiR28
Are delica’s counterfeited? If so, given the low price they would have to use really crappie steel to turn a profit. The lettering on yours is off, in places, but that may have been common for those years. Vg-10 doesn’t need professional sharpening. It’s definitely cheap compared to hap-40 or zdp, but not compared to 420, in raw materials cost or machining. Practice makes perfect(or close enough), and try to have fun while learning. Another way to tell is to check out YouTube, they have videos showing real and fakes side by side enough to be confident that what you have is one or the other. If it were fake there would be many thousands made, as frn is more expensive the fewer that are made, since the mold is most of the cost.
Clamp sharpeners are a waste of time imo unless you need to get the angle a perfect 17 degrees or so. Get a dmt diafold with coarse/fine and you won’t spend a lot of money.
What are you doubting? Of course they can make a HUGE profit from making and selling counterfeits of a $60 knife.
That said, the OPs Delica looks legit to me.
--------------------I've never had a problem sharpening any of my knives so far with my Sharpmaker. Back in 2002, I reprofiled my brand new large regular Sebenza (S30V) using only my SM. The knife came super-dull, and I wanted to take on the project myself, but SLOWLY so as not to risk messing up the blade by incorrectly removing too much metal at any one time. Yes, it went slowly; I worked at it here and there, on and off for a good while, but I eventually worked the shoulders down at 15 DPS and finished at 20 DPS, using the darker rods. Later, I also reprofiled a NIB Bemchmade Stryker (ATS-34) that also came dull in the same manner.
Would I recommend the SM as the best tool for reprofiling a blade? No. But in those instances, it worked for me. Like I mentioned, I wanted to go gradually so as not to do something I might regret. For normal resharpening, so far my SM has worked just fine for:
VG-10
S30V
S35VN
440A
440C
420HC
H1
X50 (Victorinox steel)
ATS-34
154CM
Gin-1 (G-2)
AUS-8
AUS-6
Old Schrade carbon steel
I believe there's others as well...
...and I'm not some sharpening master or guru, either. If I wanted to touch up an edge that isn't exactly 15 or 20 DPS, I simply matched the edge bevel angle to the rod by sight or by feel (so far, I haven't needed to use the magic marker method), or held a rod freehand.
There are 3 steels in knives I own that I haven't used the SM on yet, and those are:
CTS-XHP (I haven't used my knives in that steel enough to need to, though I am confident that I can do it when the time comes);
LC200N (also haven't used enough yet, but have full confidence resharpening will be easy);
S110V (which, TBH, I'm actually a bit concerned *might* present a problem to resharpen, though I haven't used my S110V Military enough to need it).
Jim
You get diamond rods like I told you earlier if you wanna listen to that guy.--------------------
Thanks Jim that is good and detailed infomation
At that point, you are just under the cost of a set of Shapton Pros. You may have to wait a bit on the shipping of those stones, but you'll have much more flexibility and life.You get diamond rods like I told you earlier if you wanna listen to that guy.
He already got SM. Its plenty strong for delica. Its user friendly and if they want they can progress to free hand from there. Taking off less metal is not a bad thing for beginners. SM gets you thinking... And if your not up to the task you pick the other route. SM weeds things out and you pick your path from there.At that point, you are just under the cost of a set of Shapton Pros. You may have to wait a bit on the shipping of those stones, but you'll have much more flexibility and life.
^^And if they return it you'll know it's real.
UPDATE
Customer service at Spyderco said they were not aware of any fakes in
the time period of 2011
I asked when they started and they said "a few years ago"
And yes, they said they can sharpen it and they would have it about two weeks.
I am amazed how Bad the engraving is on my VG10,
the G looks like a deformed 8
and the V looks like a Y, that in other items is usually a dead giveaway of a counterfit
I stropped it yesterday and it definitely improved the sharpness.
I really would like to learn how to sharpen better.
The secret seems to be in holding the hand steady and keeping the same angle.
I already knew this but seem to have some trouble doing this
I will find my spyderco sharpener and try it on some knives.
Also do you guys think should I go explain to the sharpener guy;
that as I already thought I knew and now know for sure / that VG-10 is great steel
that it can be sharpened extremely well
, I will show him how sharp it is
Because im very curious what he will say
Sounds like that sharpener guy isn't very sharp. Get a set of the sharpmaker diamond rods and forget that guy.You shouldn't really need the diamonds for VG10 but they will cut quicker.
