- Dec 6, 2020
did you try to paint the edge with a waterproof marker?
i find this method very helpful.
cheapo knives come in tough ductile steels and form malleable positive burr:Maybe the problem is the cheap-o knife steel?
After achieving the burr on the second side, how did you go about trying to remove it?Another day on the Course stone, another burr on each side, but still not much of cutting edge.
Keep going? Try something else? Maybe the problem is the cheap-o knife steel?
Have you tried sharpening on a different type of stone?Another day on the Course stone, another burr on each side, but still not much of cutting edge.
After raising a burr on both sides, try a couple of edge trailing strokes. Or edge leading strokes. Alternating the side of the blade each time. The lighter the pressure the better. This usually helps to remove the burr.Another day on the Course stone, another burr on each side, but still not much of cutting edge.
Did you gently remove it to the point where you could no longer feel it or snag a thumbnail on it?
Maybe try a $20 Norton India or crystolon first to get your technique down?
I find the India or crystolon provide good feedback to let you know when you're at the right angle and you don't have to worry about too much pressure ruining the stone.
When sharpening lower grade steels I find they respond better "softer" abrasives than on diamond.
If you go off of abrasive hardness with India being aluminum oxide and Crystolon being Silicon carbide, it's a downgrade from diamond, but the India and crystolon is much easier to learn on in my opinion. I usually stick with the standard 8 in. length unless you sharpen big blades often.I may graduate to other stones eventually. I'm especially feeling like a 6 x 2 is a little small. And I need a base, for heaven's sake.
If you raised a burr along the entire length, you've apexed (the side you had been sharpening). But technique will determine where things go from there, in concert with the steel. Soft, gummy stainless is harder to remove the burr from.Thinking about it a little more: The problem is probably that my technique is not good enough yet, and I am not reaching the apex. Or I'm reaching it, then moving my hands and messing up the bevel.
More practice, more practice.
