The human body can only maintain consistency within certain parameters and will never hold the angle consistent enough to generate a perfectly flat V bevel.
From what I understand all freehanding leads to a convex edge of some sort.
It is true that, using flat stones, you will not get a completely convex edge. Your finishing passes will need to be at a consistent angle in order to assure a crisp apex, and this will make at least the very edge a V-grind. That said, I have used bench stones to convex several edges, including doing a convex conversion on a mora companion, simply by adjusting the sharping angle little-by-little as I went. In order to carry it completely to the edge sandpaper on a somewhat soft surface may be required, but even here the skills acquired on the stones will easily translate.
On a guided system, flat bevels would be the result. Otherwise, there'll always be some amount of convex produced in a freehand edge. Some truly expert sharpeners can freehand edges that look very nearly flat in the bevels. But even then, if examined in close reference to a dead-flat standard, there would still be at least a tiny bit of convex.
I have been following your progress and pursuits with great interest, you have been getting very good advise here, and i have not chimed in, just cheering you on.J jaydiggz : I bought the Double Stuff (303MF) and the Ultra Fine Benchstone (306UF). The Double Stuff is not really what I need since it is hand-held and intended for touch-ups on the go. The Ultra Fine I haven' tried out yet.
Funny you should mention the Sharpmaker. I was just thinking of getting one, and maybe I will. It seems to be a great system. However, I would sort of like to learn free-hand sharpening. I just don't know if I want to spend the $$$$ that it would take to get the full free-hand education.
