First would be for the DMT Coarse stone + balsa wood strop coated in 1 micron diamond (DMT sells this too).
A quick look on Amazon showed the following prices for a DMT Coarse stone in the following sizes and prices:
$32.55 - 6" Long x 2" wide
$55.45 - 8" Long x 3" wide
$72.54 - 11.5" Long x 2.5" wide
That's part of my original question. Were the two stones, 1k and 6k enough. I have ruled out anything over 10k, until I start using a straight razor (right now I use a straight razor with training wheels, a safety razor) because of edge retention, and then I'd be using different strops and not a 30k glassyou can spend a ton of money and have a ton of stones and still be a poor sharpener, "Beware of the person with one sharpening stone!"
140 is too course of a jump to 1k
If you use a 140 diamond the scratches carve deep into the steel.
That's why Jason recommend the 500 grit stone.
Thanks, I must have missed that. 140 to 1000 is a big jump... Don't know how I missed that one
Why is it that our experiences are so vastly different? I've tried dollar store stones. The ones I've tried are powdery, and soak up water like a sponge. They aren't proper sharpening gear in any sense of the word. Have you found some stones that are actually dense and don't suck water in like crazy? You keep repeating this advice, over and over again, and linking to posts that you made yourself saying how great they are. Quoting yourself doesn't exactly reinforce your point.
I can't imagine that you'd say this if you had used the stones I've seen and tried. Is this all a matter of you being so cheap that you refuse to use anything that costs more than a few dollars? But you're willing to spend endless time flattening these stones on other cheap items (cinder blocks) and any other steps necessary to make them better? I just don't get it. What kind of stones did you learn to sharpen on? Certainly not these terrible, crumbly, bottom of the barrel stones.
Brian.
that was one of my questions, thanks. wasnt sure of the 1k would do that job.
right now, just plain ol steel. gonna sharpen my NRA SAK and some other cheap knives. my nice knife, a BM grip, i send back to the factory for sharpening, since a laser will do a better job then i can. I dont have any other fancy or expensive knives, so I dont see having an issue running into hard steel.
So I'm getting into sharpening, all I have right now is one of those Smith" pull through sharpeners that is completely toast...
Now I need/want to get a decent set up. I'd prefer free hand. I'm looking at a set of king Stones 1&6k. Will that be coarse enough to reprofile an edge, and fine enough to get it razor sharp? Will I need Stones on before the 1k, before the 6k and after the 6k? Or will those two be good enough. Maybe a few Arkansas Stones? I'm on a bit of a budget, around 50 bucks, maybe more
Sent from my SM-G920V using Tapatalk
oh and keep the batteries in your magic wand well charged.
sarcasm???
I picked up the ace combo stone.
Oil vs water. And if oil, I have copious amounts of tri flow at my office, will that do?
sarcasm???
I tried the tri flow. I didn't like it at all. Plain water got a much nicer edge, faster. So just gonna use free water
Can I soak the stone in 409? I hear the dishwasher is also good for cleaning stones. I've been going to town on the secondary bevel of a knife to get it straight, so I just bought a cheap coarse diamond "stone" to flatten the stone. Maybe that will help remove the oil clogged area?
I still recommend using mineral oil
