- Jun 4, 2010
HeavyHanded,
I must say I am surprised. More than surprised.
As cutting "oil" is nothing like lubricating oil . . . sharpening fluid "oil" is nothing like . . . well . . . lubricating oil.
Kerosene really is much closer to say . . . Buck sharpening stone oil than is mineral oil "Baby Oil" from the pharmacy.
To start I would go MUCH lighter weight, runnier, closer to water than motor oil and really the whole point is to have a fluid that secondarily doesn't initiate rusting of the blade but primarily it should float metal swarf out of the pores of the stone while allowing the grit of the stone to get a good bite on the steel. I find mineral oil, basically motor oil, to get a bit gummy once it gets some house dust on it. The kerosene easily cleans and floats all that off and then gets out of the way of the cutting edges of the grit of the stone.
AwwwwdnO dude.
It never fails to strike me how different folks impressions are on this topic.
I've tried lamp oil, pure silicone oil, mineral oil, and a bunch of other blends now forgotten. Am pretty sure Norton's honing oil is a thin grade of mineral oil.
What I find is the pharmacy mineral oil breaks down into lower viscosity as its worked, so the initial thickness of it helps keep it in place. It is also viscous enough to actively float a lot of debris right off the surface rather than just help prevent abrasive glazing or impacting into the pores. It actually (and I cannot explain how this happens) encourages mineral break out from the stone - the refresh rate goes up. Not all oils have this effect, and water almost not at all. The surface of my oil stones improve with time, and stay an almost velvety texture. I've never noticed it getting gummy over time, maybe an additive in the brand you tried? Most of the time I don't even wrap mine in paper between use, they sit on the shelf next my unused waterstones.
Its cheap, edible and odor free. I cannot imagine using kerosene or similar, or water based cleaning products for that matter - my hands take enough of a beating and the wife would give me the stink eye if I showed up in the kitchen with a smell and began sharpening away.
On stones such as Arkansas or other fine grained stones a thinner oil is definitely called for if available, but on combination SiC or India stones in my experience the mineral oil does all I could ask with no downsides aside from the odd spot on the front of my shirt if I get careless.
Ah well, to the OP - try some stuff and go with what works for you.
