Yes, I did read that the HR was different at different parts of the blade, including a very soft spine to keep from breaking. I am using about a 32% bevel and yes a convex blade will not ever get as sharp. A convex blade is always a better, more controlled chopping blade and so a kuk needs to be convex. I guess I just prefer a blade that will shave my arm and I cont get it to that point. I think it is possible to do that, but maybe a person needs to be more skilled than I. Thanks for all of your input, it is great.
I keep all my kuks, axes, tomahawks, everything razor sharp. Just like my knives. I use them all hard. On stuff they should cut of course. I like to use sand paper mostly. But use ceramics, diamond steels, stones, files, I even strop sometimes, just about everything there is to sharpen with I probably used. I feel the tightest I can get the metal, the better the blade cuts and slides into the wood or whatever is getting cut with the least friction . Just like a polished finish is easier to maintain than villager/ unfinished steel. When the steel is completely finished, oxidation or stains have a harder time getting in. My two cents. Dang I'm tired
Most of the blade can be used, and can be sharpened., from the tip to the beginning of the valley. At that point, it is too soft to take an edge.
If you can sharpen the valley of the recurve, take a video of it, and post it.
The steel is too soft in this region, next to the cho, and for a reason no doubt. See the area below.
And of course the definition of sharp may need to be defined.
I can sharpen there. No I'm not going to make a video.
If it came sharp, it can be resharpened. If you can't, try a different technique.
Its part of my job here, aside from having to bonk Bawanna on the noggin once in a blue moon.![]()
