afishhunter
Basic Member
- Oct 21, 2014
What company is left for you to buy from?![]()
Buck, Rough Rider, Colt, Marbles, Schrade/Imperial ...
EDIT: Almost forgot SAK and Opinel
I've gotten dull knives from all of those companies... except the foreign made Schrade/Imperial since I've never owned one of those knives. I assume you meant the foreign made knives since you often post about them.
Every company has it's hits and misses. I know you are a fan of the foreign made knives but the edges can be wild and variable. One of the worst edges that I've ever gotten from any company was from Rough Rider. On a RR whittler, the front half of one blade was sharpened on both sides. The back half was not sharpened at all.
The worst that I've gotten was from Bear and Son-- it was an unsharpened blank.
I believe Carl said this, and I will paraphrase here, that if Victorinox can put a reasonably good/workable edge on almost every knife blade they produce, why can't Case? Queen? Boker? Great Eastern? Buck?
...The current state of things presents a conundrum for me as I consider giving a nice knife to a friend. Do I give it to him new-in-tube so that he can experience it in its pristine state, but knowing that he may not possess the skill and equipment required to give it an acceptable edge? Do I sharpen it for him so that he can use it upon receipt, but deny him the new-in-tube experience? I think the best solution may be to give it new-in-tube with an offer to immediately sharpen it if he'd like me to. But, I wish I didn't even have to have this mental debate with myself.
Since a knife is a cutting tool, I expect a new one to cut. Just makes sense to me.
If it can peel an apple it's OK by me. When the original edge is dulled I'll put my own on it.
I think that a new knife should be sold sharp, but the evenness of the grind is more important to me, since I'm going to be sharpening it anyway.
The numerous Opinels I've had have all arrived very sharp indeed, carbon or stainless, one reason they're valued as superb slicers. And they strop back very satisfyingly too.
AreBeeBee, The smilies were supposed to indicate that my reply was intended to be in good fun. But you're probably right that we have different opinions based on what you've said. I disagree that I demand the "the finest, sharpest, most-perfect-shaped edge". I wouldn't recommend using a file to sharpen knives. You might try wet/dry sandpaper if you don't have appropriate stones. I don't use power tools to sharpen pocket knives. Every company makes mistakes and I've bought enough knives to get some from just about everyone. So if I were to have a one strike limit, I'd have to stop buying from a lot of companies.
I agree with what the OP said about the primary grinds. I'm MUCH more interested in getting a good primary grind (a lot of traditional knives have full flat grinds so that's the entire surface of the blade, not the edge). I'll put an edge on my knife anyway.
Ideally they'd come sharp. But I've bought enough knives not to expect it. Companies may need to switch to an automated process like Victorinox to get extremely consistent results.
I sharpen all my knives after I get them anyways so sharpness doesn't really matter, what I care about is whether the bevel is ground relatively evenly and not ridiculously steep cause those are what effect how quickly and easily I can put my own edge on it to my liking. I do think they should come sharp enough to cleanly slice phone book paper, it's not hard at all to achieve that and when you are putting the kind of care and hand craftsmanship that goes into these kinds of knives then the edge (the most important aspect!) should have the same care and quality put into it.
