That would make a nice lock for the pin, but nope.
Your close in the sense that it won't look like Saturn from the outside.
Connnngratulatuons Jared, you just won a trip for two to Jamaica on you're very own llama!Eureka! It's the keyway for the skeleton key used to lock the knife from unauthorized use in order to make it CA legal!!!
Where's my prize?![]()
Whoa, that's my arch nemesis- "more is more"! Can we add some hydraulics and cantilevers?Pin with indentations in the middle hole.
Little springs with balls in the 2 channels.
Push the pin in and the springs will lock the pin though not too tight so that with some pressure the pin can be pushed out.
Would make a cool take down knife.
But looking at the rest of the holes I doubt it unless it's just an experiment.
Thank you. :-DWhoa, that's my arch nemesis- "more is more"! Can we add some hydraulics and cantilevers?
Welcome to our ghost town by the way..
It's much simpler than that. Hint: Don't get hung up on the outline.
A diamond-shaped pin? The round holes prevent stress risers?
I was able to score a large amount of Blackwood, that I was told were reject blocks from a Cello maker. Apparently anything other than absolutely perfect straight grain is a no go in Cello making.
Needless to say, the stuff looks great. I sliced a piece off to test how it was going to cut on my bandsaw and after polishing up a bit found nice grain and chatoyance (fancy French word to describe the sheen and glimmer you see in some wood). Anyways, I think this will make for some nice scales. It was hard to photograph.
Ooooh, you're hot like Wasabi Jared! But it's even simpler than that. You're second sentence is spot on.
Needless to say, the stuff looks great. I sliced a piece off to test how it was going to cut on my band saw and after polishing up a bit found nice grain and chatoyance (fancy French word to describe the sheen and glimmer you see in some wood). Anyways, I think this will make for some nice scales. It was hard to photograph.
Purdy!!! I'm trying to resist buying one of these, but you're not making it easy...That's some purdy wood right there, I tell you what!:thumbup:
