I should note i just noticed that one side feels sharp one side feels dull when i rub my thumb perpendicular to the edge. Does that tell you guys anything? I do the same thing on both sides except the angle was slightly different....should I keep the angles the same if I can?
Thanks,
Bo
Sharpen a bit more and see if you raise a burr and maybe these spots you talk about will join with the rest of it and you will know for sure.Thanks guys, good info.
Serg: Yes I understand that stuff but the flashlight burr trick is new. This knife has shiny spots but not all the way up the knife. I'm not sure if they're burrs. What do you think?
I just remembered I have diamond matrix stones I can use which I will do tomorrow. What do you guys think of that idea?
Thanks,
Bo
Jason: So if I have a burr, why isnt it sharp?
Thanks,
Bo
Because the burr sits on top of the sharp apex.
A burr can give false sharpness or make an edge feel dull, it can also make an edge shave on one side but not the other, feel sharp on one side and not the other.
When you are having problems keep it simple. Use one stone, something in the 300-500 grit range, sharpening until you get a burr, reduce pressure to reduce the burr size, use strop or ceramic rod to remove the burr. If the edge will not slice paper and easily shave arm hair then you have done something wrong. Constructing an edge is a fairly simple process, don't complicate it... in the beginning![]()
I tried to get a burr with the 650 grit diamond matrix stone and it worked easily. So it must have been something with the stone. Any ideas?
Thanks,
Bo
